Pia on librem5 question
I immagine pia will have an app on librem5, i use another vpn, will be possible to remove that app and use openvpn with my own vpn? For security reason less app you have installed less attack vector there is, so i want to uninstall all unused app, can i do it?
PureOS is 100% free software, you can make what you want.
You can use apt autoremove to unistall PIA’s software or use the graphic interface.
