So when setting up the Admin PIN and the PIN there is not real sign or doc on limits:
Are there strict limits? It seems when setting them not really but when trying to use them I’ll get this “PIN too long” error for one or both PIN and Admin PIN. Have tried several different PINs ever sticking with the 6 or 8 char limit on the default PINs. Think the Admin PIN is the one giving me an error in HEADS with trying anything.
So after much testing those are not the same problem that i am having. That is usually showing a 20 char or less limit for use within Heads.
My issue is that even with an 8 char PIN for admin when trying to set TOTP or HOTP that the PIN entry seem to always be too long.
While the librem key seem to possibly great there is a lot of knowledge that is lacking in availability.
