I have two power-supplies, one with 100W the other the original one delivered with the librem-11, both are not recognized by the librem-11, only 60 Watt charger works. The other two are charging other devices, what is wrong?
Is the Librem 11 able to recharge when fully turned off using either power supply?
Have you reviewed the following? https://source.puri.sm/librem-11/l11-community-wiki/-/wikis/Hardware/Battery%20and%20Charging (noting particularly the comment about which port on the supplied charger to use)
The beauty of USB-PD is that if you pick a random device and a random charger, it is anyone’s guess as to whether it will work. So you have to be systematic:
- What does the device require? Exact voltage. Minimum power (current at that voltage).
- Research candidate charger to understand what it is capable of offering - a set of voltages and a maximum power at each voltage (maximum current at that voltage).
- Reject an incompatible charger.
In the absence of that approach, don’t even think about using any charger other than the one that came with the device.
The original power supply stopped working with the librem11, it works on other devices however. Luckily one spare power supply i own is still recognized, all others aren’t.
That did not help
Okay, contact Purism support:
