Is there a possibility to rearrange the default icons on the Librem 5, 5 usa?
You can remove the apps from the “dock” at the top and then re-add every app in the order you want. Just tap and hold on an app icon to bring up the pop-up menu with the add or remove option.
Thank you for your help.
