Problem importing contacts using .vcf file [SOLVED]
OS: PureOS 10/Byzanthium
Contacts app: 43.beta
Received the L5 more than a year ago, update it once a month. Do not use it all the time, can make calls, receive calls, etc.
Want to import a contacts.vcf file from another phone in the Librem 5, used a USB-drive to copy this file on the L5.
  1. Attempt using the Contacts app
In the Contacts app, Import → select file:
Continue Import?
By continuing you will import 456 contacts
Press: Continue → app crashes.
*** Question: How can debug this, see what’s wrong?
The file was VCF V2, same result after I converted to VCF V3.
More#1:
In the Contacts app → Preferences:
Primary Address Book
Local Address Book
Sometimes there is a ‘check’ after Local Address Book, sometimes there isn’t.
More#2:
Create contact via the Contacts app, using the ‘+’ button:
Type: aaa
Press: Add
Response is Alert message:
No primary addressbook configured
Close
  1. Attempt using the librem5-goodies script: l5-contacts-importer
Installed librem5-goodies.
Then run:
l5-contacts-importer /home/purism/Documents/vvv.vcf
Result:
Writing: card_import_L5_01.vcf
Writing: card_import_L5_02.vcf
Writing: card_import_L5_456.vcf
[ERROR] : accessing database: Timeout was reached
etc.
No contacts were imported.
More#1:
In the l5-contacts-importer, printed the data of the file send to syncevolution, seems correct.
I am the opposite of syncevolution guru, but trying this:
syncevolution --print-items backend=evolution-contacts
also gives the result:
  1. For what’s it worth there is an endless amount of lines in journalctl all related to tracker-miner, tracker-store, and lines like:
Failed to start Tracker metadata database store and lookup manager.
and
tracker–store.service: Failed with result ‘exit code’.
Any help appreciated.
Manually add each individual contact as an entry.
It’s been so long, but I remember a package that could be installed librem5-goodies which had an import tool for .vcf files.
Maybe run gnome-contacts at the command line. If it crashes then maybe something will get output to the terminal.
Otherwise, make a copy of the source VCF file edited down so that just the first card remains. Try to import that. If it works, maybe chop the original file in half and import each half separately, applying this recursively to any failed half. (This may be a good strategy if there’s just one or two contacts that are for some reason causing a problem.)
I think librem5-goodies is obsolete for this purpose.
44 How to export and import contacts
   Export all contacts to a VCF file:
   syncevolution --export /home/purism/guru/contacts.vcf backend=evolution-contacts
   Wipe out all contacts:
   syncevolution --delete-items backend=evolution-contacts --luids '*'
   Import contacts from a VCF file:
   syncevolution --import test.vcf backend=evolution-contacts
   #0: pas-id-552B785D00000008
   For more operations see also:
   https://guru-1.gitbook.io/bq-aquaris-e-4-5-ubuntu-phone/en/chapter9
Thanks but as I mentioned, manual entry via the Contacts app also fails: No primary addressbook configured
Thanks but as mentioned above I tried l5-contacts-importer, but get an error: [ERROR] : accessing database: Timeout was reached.
Thanks but as mentioned above, I tried syncevolution, and get an error, same for your suggestion ‘syncevolution --export /home/purism/guru/contacts.vcf backend=evolution-contacts’: ’ [ERROR] : accessing database: Timeout was reached’.
I guess something is not running, installed, or a rights problem …
Starting gnome-contacts from the command line pops the contacts app with the message: Primary address book not found. But not always. As mentioned in the Contacts app Preferences Local Address Book is sometimes checked but sometimes is un-checkled.
syncevolution --print-databases | grep “system-address-book”
Result:
Personal (system-address-book)
Result:
Maybe something is not installed, local database is missing? Any idea where this file should be?
Refer: Tips & Tricks · Wiki · Librem5 / Librem 5 Community Wiki · GitLab
(I know this is the right path because when I upgraded from amber to byzantium, I carefully copied that file away, reflashed, then carefully copied that file back - rather than export and import around the reflash, which is probably the “right” way to do it.)
Thank you all, problem is SOLVED. Received my L5 Oct. 2022.
Tested it, worked and updated once a month.
It appeared ~/.local and subdirs/files were owned by root.
I noticed this when looking in journalctl:
The relationship key file directory /home/purism/.local/share/folks could not be created.
Error creating directory /home/purism/.local/share/folks: Permission denied
Changed ownership this recursively to purism:purism
Reinstalled syncevolution: sudo apt install --reinstall syncevolution
Reboot
And now the Contacts app importing works! Yeah!
Also, some created files in .local/share and messages in journalctl reduced significantly
I am happy (for the moment) …
Good to hear.
OK, that’s weird but probably no chance of getting to the bottom of that this long afterwards unless you reflashed the phone yourself.
Nope, never flashed the phone or messed with the phone, only did updates from the gui. When updating, I always got an alert that a file could not be found, but the updates worked anyway. I asked here about this but to no avail.
There was only one directory in ~/.local/share: applications.
Agree, this is weird, maybe something in the batchj L5 Oct. 2022? I don’t know.
After changing ownership, there are now many directories in ~/.local/share = normal.
Also had to sudo apt install --reinstall squeekboard.
Btw, tested my ,vcf file on my ubuntu 22.04 machine. installed syncevolution, modified the l5-contacts-importer script a little bit and imported without problem.
