Problem sending pdf document in email
HI,
When I attempt to send a pdf document via email, which is the only format that people are able to print, all that shows up is illegible code. Help! I need to send documents to my patients for them to print out and am unable to do so. What am I doing wrong?
Thanks
I did not find the right solution from the internet.
References:
https://forum.openoffice.org/en/forum/viewtopic.phpf=5&t=84150
web hosting marketing
What are using to send emails? Are you using purebrowser or are you using an email client (an app on your computer)?
