Problems connecting to Librem.one VPN Tunnel
I have a Purism Librem 13 with PureOS and recently started having problems connecting to the Librem.one VPN tunnel.
When attempting to connect, the attempt eventually times out. I was getting (possibly) weird results from nslookup us-california.privateinternetaccess.com which would give me two different IP addresses. Also, ping us-california.privateinternetaccess.com would fail.
Just now, I was able to connect to the VPN just fine, so it may be on-and-off kind of a problem.
Two (or multiple) IP addresses is perfectly reasonable and relatively normal. In fact when I looked just now, I got 14 IP addresses for that domain.
It was probably a one-off but if it happens again, it may help to record here what the IP addresses are.
ping doesn’t work for me either. It is legitimate, but unhelpful, for a host to refuse to respond to ping requests or for intervening network equipment to block ping requests.
