I’m trying the install the following, but it seems to be not complete at the end, even if it says Installation complete.
sudo flatpak install goodvibes
Looking for matches?
Found similar ref(s) for ?goodvibes? in remote ?flathub? (system).
Use this remote? [Y/n]:
Found ref ?app/io.gitlab.Goodvibes/aarch64/stable? in remote ?flathub? (system).
Use this ref? [Y/n]:
io.gitlab.Goodvibes permissions:
ipc network fallback-x11 pulseaudio
wayland x11 dri file access [1]
dbus access [2] bus ownership [3]
[1] xdg-run/dconf, ~/.config/dconf:ro
[2] ca.desrt.dconf
[3] org.mpris.MediaPlayer2.Goodvibes
ID Branch Op Remote Download
1. [?] io.gitlab.Goodvibes.Locale stable i flathub 7.0?kB / 65.7?kB
2. [?] io.gitlab.Goodvibes stable i flathub 254.9?kB / 411.4?kB
Note the question marks [?]
and in the last column the download does not match what should be downloaded.
What could I do?
