Hi there. I have problems.
My computer was freezing. Then I installed firmwire for realtek from debian repos. It fixed problems that sudo dmesg
gives me, but when I’m using Ardour it still froze very often. Maybe It’s because I’m using kxstudio repo for plugins? Give me a sign if it’s a cause of problems. I don’t see something red in my terminal using sudo dmesg
And one another problem is that I can’t for some reason install vst plugins for obs with wine. When I trying launch wine it gives that:
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
wine32:i386 : Depends: libc6:i386 (>= 2.17) but it is not going to be installed
Depends: libwine:i386 (= 1.8.7-2) but it is not going to be installed
Recommends: wine:i386 (= 1.8.7-2)
E: Unable to correct problems, you have held broken packages.
What can you suggest with this?
I’ll be very appreciated if you will help me with this 2 problems
