Protect yourself from Pegasus
Just thought I would share…
You need a Griffon, Pegasi are one of Griffon’s favorite prey.
Pegasus is a spyware and thus, it is likely to take precautionary measures to protect yourself from it. As time is passing by, Pegasus is just getting stronger. However, it is said that if a device is affected by the spyware, the victims can actually do nothing as it is a ‘zero-day attack with user-less interaction, in-memory, self-destruction, encryption and persistent capabilities’. Hence, it is important to protect your devices before getting exposed to Pegasus. Lock your device with a passcode to protect your data. Also you can load the backup into a Linux instance for using ISO file and mount it on a disc. Besides, pin-enabled, fingerprint or face lock systems can also protect your device.
