I just installed Pure OS 10 on a Lenovo computer and I am very satisfied with it. I am having one issue where I cannot seem to add an additional user. When I go to settings it shows the original user added at installation but no way to add any more. Any help appreciated. This install was with Beta build.
I confirm I was able to repeat the issue on my end. The workaround was to create user manually using command line.
FYI I contacted Purism support about this and they confirmed the issue and are working on it with the developers, that was on July 4th.
Thanks for the conformation on the issue. I will watch for a fix.
Thanks for the info on creating new user via command line.
