Puremail Will Not Execute / Run
Puremail crashes when I try to run it. From the command line, I get:
XPCOMGlueLoad error for file /usr/lib/puremail/libxul.so:
libhunspell-1.4.so.0: cannot open shared object file: No such file or directory
Couldn’t load XPCOM.
Help appreciated.
I haven’t had this problem, so I’m just guessing really, but have you tried:
as root:
apt install libhunspell-1.4-0
Ouch! Crashers on start are unacceptable, could you please report this in tracker.pureos.net so that PureOS developers can see it and (and that way you can subscribe to it and get notifications about the fix, too)?
Let me try @knoqi … and i will get back to you when i do it.
[Update: there is no package listed under that name so it gives an error. ]
@jeff yes, i can do that … heading over there now … thanks for the heads up on the proper location. jmh
I’ve already opened a ticket about this issue: https://tracker.pureos.net/T342.
