Can PureOS 3 be installed onto Virtualbox?
Thank you
Short answer: yes.
I’m actually having a hard time getting it to work on VirtualBox. Is there something I need to do or look out for when trying to install?
Is there any error report or something? You can try here: https://wiki.debian.org/VirtualBox
This system is not currently set up to build kernel modules (system extensions).
Running the following commands should set the system up correctly:
apt-get install linux-headers-4.12.0-1-amd64
(The last command may fail if your system is not fully updated.)
apt-get install linux-headers-amd64
With
I get an error saying no package found with the regular expression linux-headers-4.12.0-1-amd64
Any news?
Make sure to run sudo apt update before trying to install.
No did not investigate further. I did sudo apt-get update.
It is working now.
