Hello,
newbie here, just have my Dell Precision M6400 install PureOS 10 Byzantium…everything great just never find the way to get wifi to work…help please…
System:
Kernel: 5.10.0-34-amd64 x86_64 bits: 64 compiler: gcc v: 10.2.1
Desktop: GNOME 3.38.6 tk: GTK 3.24.27 wm: gnome-shell dm: GDM3 3.38.2.1
Distro: PureOS 10 (Byzantium) base: Debian 11.7 bullseye
Machine:
Type: Portable System: Dell product: Precision M6400 v: N/A
serial: Chassis: type: 8 serial:
Mobo: Dell model: 0D138P serial: BIOS: Dell v: A12
date: 12/11/2011
Memory:
RAM: total: 15.61 GiB used: 1 GiB (6.4%)
RAM Report:
permissions: Unable to run dmidecode. Root privileges required.
CPU:
Info: Quad Core model: Intel Core2 Extreme Q9300 bits: 64 type: MCP
arch: Penryn rev: A L2 cache: 6 MiB
flags: lm nx pae sse sse2 sse3 sse4_1 ssse3 vmx bogomips: 20216
Speed: 1596 MHz min/max: 1600/2535 MHz boost: enabled Core speeds (MHz):
1: 1596 2: 1596 3: 1596 4: 1596
Graphics:
Device-1: NVIDIA G92GLM [Quadro FX 3700M] vendor: Dell driver: nouveau
v: kernel bus ID: 01:00.0 chip ID: 10de:061e class ID: 0300
Display: x11 server: X.Org 1.20.11 compositor: gnome-shell driver:
loaded: modesetting unloaded: fbdev,vesa resolution: 1920x1200~60Hz
s-dpi: 96
OpenGL: renderer: NV92 v: 3.3 Mesa 21.2.6 direct render: Yes
Audio:
Device-1: Intel 82801I HD Audio vendor: Dell driver: snd_hda_intel
v: kernel bus ID: 00:1b.0 chip ID: 8086:293e class ID: 0403
Sound Server: ALSA v: k5.10.0-34-amd64
Network:
Device-1: Broadcom NetXtreme BCM5761e Gigabit Ethernet PCIe vendor: Dell
driver: tg3 v: kernel port: df00 bus ID: 09:00.0 chip ID: 14e4:1680
class ID: 0200
IF: enp9s0 state: up speed: 100 Mbps duplex: full mac:
Device-2: Broadcom BCM4322 802.11a/b/g/n Wireless LAN vendor: Dell
driver: b43-pci-bridge v: N/A port: df00 bus ID: 0c:00.0
chip ID: 14e4:432b class ID: 0280
Bluetooth:
Device-1: Broadcom Bluetooth Device type: USB driver: btusb v: 0.8
bus ID: 2-1:2 chip ID: 0a5c:2046 class ID: fe01 serial:
Report: ID: hci0 state: up running bt-v: 1.2 lmp-v: 2.1 sub-v: 420e
hci-v: 2.1 rev: 5000 address:
Drives:
Local Storage: total: 953.88 GiB used: 5.35 GiB (0.6%)
ID-1: /dev/sda vendor: Timetec model: SATA 512GB size: 476.94 GiB
speed: 3.0 Gb/s rotation: SSD serial: rev: 6B0 scheme: GPT
ID-2: /dev/sdb vendor: Kingston model: SNVP325S2512GB size: 476.94 GiB
speed: 3.0 Gb/s rotation: SSD serial: rev: 0201 scheme: GPT
Partition:
ID-1: / size: 457.55 GiB used: 5.23 GiB (1.1%) fs: ext4 dev: /dev/sda5
ID-2: /boot size: 973.4 MiB used: 119.4 MiB (12.3%) fs: ext4
dev: /dev/sda4
Swap:
ID-1: swap-1 type: zram size: 8 GiB used: 0 KiB (0.0%) priority: 100
dev: /dev/zram0
ID-2: swap-2 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3
Sensors:
System Temperatures: cpu: 38.0 C mobo: N/A sodimm: SODIMM C gpu: nouveau
temp: 34.0 C
Fan Speeds (RPM): cpu: 0
Repos:
Packages: apt: 1768
