PureOS Upgrade
Hey y’all, it’s been quite a few minutes since I’ve posted. I still have my original Librem 13 v4 from 2019, and it’s still (mostly) going strong, but it’s been losing functionality for various applications, and I’m interested in upgrading to Crimson. Conveniently, the “PureOS Upgrade” app was provided for that purpose, UNFORTUNATELY, it doesn’t seem to be working. I have fully upgraded byzantium to the best of my knowledge, and removed all non-byzantum repos, and I have even tried the --force tag to get it to run, but all it ever tells me is “Unsupported system”
Any ideas?
What’s the output of lsb_release -a?
username@Librem13v4:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description: Debian GNU/Linux 11 (bullseye)
Release: 11
Codename: bullseye
The upgrader checks whether it’s running on PureOS 10, and your system identifies itself as Debian 11 instead. Seems like you may have made a frankendebian (frankenpureos?).
Judging from this result your system may be broken in all sorts of unexpected ways, but if you want to attempt to clean it up apt-forktracer may be a helpful tool for that.
Or install crimson from scratch - after performing appropriate backups.
Or maybe this computer is just running Debian??
Huh. Not sure when/how that would have happened. I have only ever (I think) used the byzantium repos for OS upgrades. I did install debian packages for I think steam and docker at some point, and maybe one or two other applications, but that shouldn’t “break” my OS, right?
So, @irvinewade I did a full clonezilla backup in preparation of running PureOS Upgrade, I’m pretty sure it’s bootable in extremis, so is that a sufficient backup? Or do I need some sort of firmware backup too?
Thanks for the advice, keep it coming!
Personally, I always just dd image the entire disk to a portable (external) disk (and I guess you can get the same effect with Gnome Disks). To make the image I always use Live Boot - so that the image has integrity.
The main thing that you are looking to preserve is your personal files (documents, spreadsheets, media, …), so that you can copy them back after the install from scratch but also your settings in case you need to refer to them.
I would not suggest that firmware needs to be backed up.
Yeah, I should be good - the clonezilla backup was done with live boot. I have also been making it a point to save files etc. to my NVMe auxiliary (non-system) drive (including my backup), so I’ll probably just do a clean install. Thanks!
