Here’s the output from building after linking python to pyton3.9. I says it can compile successfully, but it also mentions in the end that it lacks python2
$ sudo ln -s /bin/python3.9 /bin/python
[sudo] password for user:
~/updates/coreboot$ make
Skipping submodule '3rdparty/amd_blobs'
Skipping submodule '3rdparty/blobs'
Skipping submodule '3rdparty/cmocka'
Skipping submodule '3rdparty/fsp'
Skipping submodule '3rdparty/intel-microcode'
Skipping submodule '3rdparty/qc_blobs'
Checking out SeaBIOS revision 155821a1990b6de78dde5f98fa5ab90e802021e0
Switched to branch 'master'
Your branch is up to date with 'origin/master'.
Deleted branch coreboot (was ebd8e08).
Switched to a new branch 'coreboot'
Applying /home/user/updates/coreboot/payloads/external/SeaBIOS/patches/0001-make-bootsplash-sane.patch
Applying: make bootsplash sane
Applying /home/user/updates/coreboot/payloads/external/SeaBIOS/patches/0002-boot.c-don-t-exit-boot-menu-on-ESC.patch
Applying: boot.c: don't exit boot menu on 'ESC'
CONFIG SeaBIOS 155821a1990b6de78dde5f98fa5ab90e802021e0
# configuration written to /home/user/updates/coreboot/payloads/external/SeaBIOS/seabios/.config
MAKE SeaBIOS 155821a1990b6de78dde5f98fa5ab90e802021e0
Build Kconfig config file
Compile checking out/src/misc.o
Compile checking out/src/stacks.o
Compile checking out/src/output.o
Compile checking out/src/string.o
Compile checking out/src/block.o
Compile checking out/src/cdrom.o
Compile checking out/src/disk.o
Compile checking out/src/mouse.o
Compile checking out/src/kbd.o
Compile checking out/src/system.o
Compile checking out/src/serial.o
Compile checking out/src/sercon.o
Compile checking out/src/clock.o
Compile checking out/src/resume.o
Compile checking out/src/pnpbios.o
Compile checking out/src/vgahooks.o
Compile checking out/src/pcibios.o
Compile checking out/src/apm.o
Compile checking out/src/cp437.o
Compile checking out/src/hw/pci.o
Compile checking out/src/hw/timer.o
Compile checking out/src/hw/rtc.o
Compile checking out/src/hw/dma.o
Compile checking out/src/hw/pic.o
Compile checking out/src/hw/ps2port.o
Compile checking out/src/hw/serialio.o
Compile checking out/src/hw/usb.o
Compile checking out/src/hw/usb-uhci.o
Compile checking out/src/hw/usb-ohci.o
Compile checking out/src/hw/usb-ehci.o
Compile checking out/src/hw/usb-hid.o
Compile checking out/src/hw/usb-msc.o
Compile checking out/src/hw/usb-uas.o
Compile checking out/src/hw/blockcmd.o
Compile checking out/src/hw/floppy.o
Compile checking out/src/hw/ata.o
Compile checking out/src/hw/ramdisk.o
Compile checking out/src/hw/lsi-scsi.o
Compile checking out/src/hw/esp-scsi.o
Compile checking out/src/hw/megasas.o
Compile checking out/src/hw/mpt-scsi.o
Compile checking out/src/post.o
Compile checking out/src/e820map.o
Compile checking out/src/malloc.o
Compile checking out/src/romfile.o
Compile checking out/src/x86.o
Compile checking out/src/optionroms.o
Compile checking out/src/pmm.o
Compile checking out/src/font.o
Compile checking out/src/boot.o
Compile checking out/src/bootsplash.o
Compile checking out/src/jpeg.o
Compile checking out/src/bmp.o
Compile checking out/src/tcgbios.o
Compile checking out/src/sha1.o
Compile checking out/src/hw/pcidevice.o
Compile checking out/src/hw/ahci.o
Compile checking out/src/hw/pvscsi.o
Compile checking out/src/hw/usb-xhci.o
Compile checking out/src/hw/usb-hub.o
Compile checking out/src/hw/sdcard.o
Compile checking out/src/fw/coreboot.o
Compile checking out/src/fw/lzmadecode.o
Compile checking out/src/fw/multiboot.o
Compile checking out/src/fw/csm.o
Compile checking out/src/fw/biostables.o
Compile checking out/src/fw/paravirt.o
Compile checking out/src/fw/shadow.o
Compile checking out/src/fw/pciinit.o
Compile checking out/src/fw/smm.o
Compile checking out/src/fw/smp.o
Compile checking out/src/fw/mtrr.o
Compile checking out/src/fw/xen.o
Compile checking out/src/fw/acpi.o
Compile checking out/src/fw/mptable.o
Compile checking out/src/fw/pirtable.o
Compile checking out/src/fw/smbios.o
Compile checking out/src/fw/romfile_loader.o
Compile checking out/src/fw/dsdt_parser.o
Compile checking out/src/hw/virtio-ring.o
Compile checking out/src/hw/virtio-pci.o
Compile checking out/src/hw/virtio-mmio.o
Compile checking out/src/hw/virtio-blk.o
Compile checking out/src/hw/virtio-scsi.o
Compile checking out/src/hw/tpm_drivers.o
Compile checking out/src/hw/nvme.o
Compiling whole program out/ccode32flat.o
Compiling whole program out/code32seg.o
Compiling whole program out/ccode16.o
Compiling to assembler out/src/asm-offsets.s
Generating offset file out/asm-offsets.h
Compiling (16bit) out/romlayout.o
Building ld scripts
Version: rel-1.14.0-2-gebd8e08
Fixed space: 0xe05b-0x10000 total: 8101 slack: 14 Percent slack: 0.2%
16bit size: 35872
32bit segmented size: 1699
32bit flat size: 32237
32bit flat init size: 53920
Lowmem size: 2240
f-segment var size: 1392
Linking out/rom16.o
Stripping out/rom16.noexec.o
Linking out/rom32seg.o
Stripping out/rom32seg.noexec.o
Linking out/rom.o
Prepping out/bios.bin.prep
Total size: 131008 Fixed: 71200 Free: 64 (used 100.0% of 128KiB rom)
Creating out/bios.bin.elf
Compile checking out/vgasrc/vgainit.o
Compile checking out/vgasrc/vgabios.o
Compile checking out/vgasrc/vgafb.o
Compile checking out/vgasrc/swcursor.o
Compile checking out/vgasrc/vgafonts.o
Compile checking out/vgasrc/vbe.o
Compile checking out/vgasrc/stdvga.o
Compile checking out/vgasrc/stdvgamodes.o
Compile checking out/vgasrc/stdvgaio.o
Compile checking out/vgasrc/clext.o
Compile checking out/vgasrc/svgamodes.o
Compile checking out/vgasrc/atiext.o
Compile checking out/vgasrc/bochsvga.o
Compile checking out/vgasrc/geodevga.o
Compile checking out/vgasrc/cbvga.o
Compile checking out/vgasrc/bochsdisplay.o
Compile checking out/vgasrc/ramfb.o
Compiling whole program out/vgaccode16.raw.s
Fixup VGA rom assembler
Compiling (16bit) out/vgaentry.o
Precompiling out/vgasrc/vgalayout.lds
Linking out/vgarom.o
Extracting binary out/vgabios.bin.raw
Finalizing rom out/vgabios.bin
CREATE build/mainboard/purism/librem_cnl/cbfs-file.Q4KNOL.out (from /home/user/updates/coreboot/.config)
IASL build/dsdt.aml
Intel ACPI Component Architecture
ASL+ Optimizing Compiler/Disassembler version 20200925
Copyright (c) 2000 - 2020 Intel Corporation
coreboot toolchain v2021-04-06_7014f8258e
dsdt.asl 144: Name (MCRS, ResourceTemplate ()
Remark 2173 - ^ Creation of named objects within a method is highly inefficient, use globals or method local variables instead (\_SB.PCI0._CRS)
dsdt.asl 277: Name (BUF0, ResourceTemplate ()
Remark 2173 - ^ Creation of named objects within a method is highly inefficient, use globals or method local variables instead (\_SB.PCI0.PDRC._CRS)
dsdt.asl 398: OperationRegion (PCRD, SystemMemory, PCRB (Arg0) + Arg1, 4)
Remark 2173 - ^ Creation of named objects within a method is highly inefficient, use globals or method local variables instead (\_SB.PCI0.PCRR)
dsdt.asl 407: OperationRegion (PCRD, SystemMemory, PCRB (Arg0) + Arg1, 4)
Remark 2173 - ^ Creation of named objects within a method is highly inefficient, use globals or method local variables instead (\_SB.PCI0.PCRA)
dsdt.asl 417: OperationRegion (PCRD, SystemMemory, PCRB (Arg0) + Arg1, 4)
Remark 2173 - ^ Creation of named objects within a method is highly inefficient, use globals or method local variables instead (\_SB.PCI0.PCRO)
dsdt.asl 548: OperationRegion (PREG, SystemMemory, GADD (Arg0), 4)
Remark 2173 - ^ Creation of named objects within a method is highly inefficient, use globals or method local variables instead (\_SB.PCI0.GRXS)
dsdt.asl 558: OperationRegion (PREG, SystemMemory, GADD (Arg0), 4)
Remark 2173 - ^ Creation of named objects within a method is highly inefficient, use globals or method local variables instead (\_SB.PCI0.GTXS)
dsdt.asl 568: OperationRegion (PREG, SystemMemory, GADD (Arg0), 4)
Remark 2173 - ^ Creation of named objects within a method is highly inefficient, use globals or method local variables instead (\_SB.PCI0.STXS)
dsdt.asl 577: OperationRegion (PREG, SystemMemory, GADD (Arg0), 4)
Remark 2173 - ^ Creation of named objects within a method is highly inefficient, use globals or method local variables instead (\_SB.PCI0.CTXS)
dsdt.asl 586: OperationRegion (PREG, SystemMemory, GADD (Arg0), 4)
Remark 2173 - ^ Creation of named objects within a method is highly inefficient, use globals or method local variables instead (\_SB.PCI0.GPMO)
dsdt.asl 597: OperationRegion (PREG, SystemMemory, GADD (Arg0), 4)
Remark 2173 - ^ Creation of named objects within a method is highly inefficient, use globals or method local variables instead (\_SB.PCI0.GTXE)
dsdt.asl 610: OperationRegion (PREG, SystemMemory, GADD (Arg0), 4)
Remark 2173 - ^ Creation of named objects within a method is highly inefficient, use globals or method local variables instead (\_SB.PCI0.GRXE)
dsdt.asl 895: Name (IQAA, Package () {
Remark 2173 - ^ Creation of named objects within a method is highly inefficient, use globals or method local variables instead (\_SB.PCI0.IRQM)
dsdt.asl 900: Name (IQAP, Package () {
dsdt.asl 905: Name (IQBA, Package () {
dsdt.asl 910: Name (IQBP, Package () {
dsdt.asl 915: Name (IQCA, Package () {
dsdt.asl 920: Name (IQCP, Package () {
dsdt.asl 925: Name (IQDA, Package () {
dsdt.asl 930: Name (IQDP, Package () {
dsdt.asl 1274: OperationRegion (PSCR, SystemMemory,
Remark 2173 - ^ Creation of named objects within a method is highly inefficient, use globals or method local variables instead (\_SB.PCI0.UPWE)
ASL Input: dsdt.asl - 45156 bytes 1342 keywords 2321 source lines
AML Output: dsdt.aml - 14541 bytes 815 opcodes 527 named objects
Compilation successful. 0 Errors, 0 Warnings, 21 Remarks, 471 Optimizations, 53 Constants Folded
IASL 3150 2158 warning types were ignored!
IASL build/dsdt.aml disassembled correctly.
/bin/sh: 1: python2: not found
make: *** [src/drivers/intel/fsp2_0/Makefile.inc:79: build/Fsp_M.fd] Error 127
So changing that python2 to python3 seems to work fine:
make
GEN build.h
CC bootblock/arch/x86/id.o
CC bootblock/lib/version.o
LINK cbfs/fallback/bootblock.debug
OBJCOPY cbfs/fallback/bootblock.elf
OBJCOPY bootblock.raw.elf
OBJCOPY bootblock.raw.bin
CC romstage/lib/version.o
LINK cbfs/fallback/romstage.debug
OBJCOPY cbfs/fallback/romstage.elf
CC ramstage/lib/version.o
CC smm/lib/version.o
OBJCOPY ramstage/cpu/x86/smm/smm.manual
CC generated/ramstage.o
CC cbfs/fallback/ramstage.debug
CREATE build/mainboard/purism/librem_cnl/cbfs-file.p4JV7T.out (from /home/user/updates/coreboot/.config)
Create FSP component file 'build/Fsp_S.fd'
Create FSP component file 'build/Fsp_M.fd'
Create FSP component file 'build/Fsp_T.fd'
MICROCODE cpu_microcode_blob.bin
3rdparty/purism-blobs/mainboard/purism/librem_cnl/cpu_microcode_blob.bin
CC postcar/mainboard/purism/librem_cnl/static.o
CC postcar/acpi/acpi_pm.o
CC postcar/arch/x86/boot.o
CC postcar/arch/x86/cf9_reset.o
CC postcar/arch/x86/cpu_common.o
CC postcar/arch/x86/exception.o
CC postcar/arch/x86/exit_car.o
CC postcar/arch/x86/gdt_init.o
CC postcar/arch/x86/idt.o
CC postcar/arch/x86/memcpy.o
CP postcar/arch/x86/memlayout.ld
CC postcar/arch/x86/memmove.o
CC postcar/arch/x86/memset.o
CC postcar/arch/x86/mmap_boot.o
CC postcar/arch/x86/post.o
CC postcar/arch/x86/postcar.o
CC postcar/arch/x86/timestamp.o
CC postcar/commonlib/bsd/cbfs_mcache.o
CC postcar/commonlib/bsd/cbfs_private.o
CC postcar/commonlib/bsd/lz4_wrapper.o
CC postcar/commonlib/cbfs.o
CC postcar/commonlib/iobuf.o
CC postcar/commonlib/mem_pool.o
CC postcar/commonlib/region.o
CC postcar/console/console.o
CC postcar/console/die.o
CC postcar/console/init.o
CC postcar/console/post.o
CC postcar/console/printk.o
CC postcar/console/vsprintf.o
CC postcar/console/vtxprintf.o
CC postcar/cpu/x86/lapic/boot_cpu.o
CC postcar/cpu/x86/mtrr/debug.o
CC postcar/cpu/x86/pae/pgtbl.o
CC postcar/cpu/x86/smm/tseg_region.o
CC postcar/cpu/x86/tsc/delay_tsc.o
CC postcar/device/device_const.o
CC postcar/device/pci_early.o
CC postcar/device/pci_ops.o
CC postcar/drivers/i2c/designware/dw_i2c.o
CC postcar/drivers/intel/fsp2_0/hand_off_block.o
CC postcar/drivers/pc80/pc/i8254.o
CC postcar/drivers/pc80/rtc/mc146818rtc.o
CC postcar/drivers/pc80/rtc/mc146818rtc_boot.o
CC postcar/drivers/pc80/tpm/tis.o
CC postcar/drivers/spi/bitbang.o
CC postcar/drivers/spi/boot_device_rw_nommap.o
CC postcar/drivers/spi/spi-generic.o
CC postcar/drivers/spi/spi_flash.o
CC postcar/ec/purism/librem-ec/librem_ec.o
CC postcar/lib/boot_device.o
CC postcar/lib/bootmode.o
CC postcar/lib/cbfs.o
CC postcar/lib/cbmem_common.o
CC postcar/lib/cbmem_console.o
CC postcar/lib/crc_byte.o
CC postcar/lib/delay.o
CC postcar/lib/ext_stage_cache.o
CC postcar/lib/fmap.o
CC postcar/lib/gcc.o
CC postcar/lib/halt.o
CC postcar/lib/hexdump.o
CC postcar/lib/imd.o
CC postcar/lib/imd_cbmem.o
CC postcar/lib/libgcc.o
CC postcar/lib/lzma.o
CC postcar/lib/lzmadecode.o
CC postcar/lib/memchr.o
CC postcar/lib/memcmp.o
CC postcar/lib/prog_loaders.o
CC postcar/lib/prog_ops.o
CP postcar/lib/program.ld
CC postcar/lib/reset.o
CC postcar/lib/rmodule.o
CC postcar/lib/romstage_handoff.o
CC postcar/lib/string.o
CC postcar/lib/timestamp.o
CC postcar/lib/version.o
CC postcar/security/memory/memory.o
CC postcar/security/tpm/tspi/tspi.o
CC postcar/security/tpm/tss/tcg-1.2/tss.o
CC postcar/soc/intel/cannonlake/gspi.o
CC postcar/soc/intel/cannonlake/i2c.o
CC postcar/soc/intel/cannonlake/pmutil.o
CC postcar/soc/intel/cannonlake/spi.o
CC postcar/soc/intel/cannonlake/uart.o
CC postcar/soc/intel/common/block/chip/chip.o
CC postcar/soc/intel/common/block/cpu/car/exit_car.o
CC postcar/soc/intel/common/block/fast_spi/fast_spi.o
CC postcar/soc/intel/common/block/fast_spi/fast_spi_flash.o
CC postcar/soc/intel/common/block/gspi/gspi.o
CC postcar/soc/intel/common/block/i2c/i2c.o
CC postcar/soc/intel/common/block/lpss/lpss.o
CC postcar/soc/intel/common/block/pmc/pmclib.o
CC postcar/soc/intel/common/block/smbus/tco.o
CC postcar/soc/intel/common/block/smm/smm.o
CC postcar/soc/intel/common/block/spi/spi.o
CC postcar/soc/intel/common/block/systemagent/memmap.o
CC postcar/soc/intel/common/block/systemagent/systemagent_early.o
CC postcar/soc/intel/common/block/timer/timer.o
CC postcar/soc/intel/common/block/uart/uart.o
CC postcar/soc/intel/common/reset.o
LINK cbfs/fallback/postcar.debug
# configuration written to /home/user/updates/coreboot/payloads/coreinfo/.config
*** Default configuration is based on '/home/user/updates/coreboot/payloads/coreinfo/../libpayload/configs/defconfig-tinycurses'
# configuration written to /home/user/updates/coreboot/payloads/coreinfo/.lp.config
LPGCC cpuinfo_module.o
LPAS cpuid.S.o
LPGCC pci_module.o
LPGCC coreboot_module.o
LPGCC nvram_module.o
LPGCC bootlog_module.o
LPGCC ramdump_module.o
LPGCC multiboot_module.o
LPGCC cbfs_module.o
LPGCC timestamps_module.o
LPGCC coreinfo.o
CC libpci/libpci.libpci.o
AR /home/user/updates/coreboot/payloads/coreinfo/libpayload/libpci.a
CC arch/x86/main.libc.o
CC arch/x86/sysinfo.libc.o
CC arch/x86/timer.libc.o
CC arch/x86/coreboot.libc.o
CC arch/x86/util.libc.o
CC arch/x86/exec.libc.o
CC arch/x86/virtual.libc.o
CC arch/x86/selfboot.libc.o
CC arch/x86/exception_asm.libc.o
CC arch/x86/exception.libc.o
CC arch/x86/delay.libc.o
CC crypto/sha1.libc.o
CC libc/malloc.libc.o
CC libc/printf.libc.o
CC libc/console.libc.o
CC libc/string.libc.o
CC libc/memory.libc.o
CC libc/ctype.libc.o
CC libc/ipchecksum.libc.o
CC libc/lib.libc.o
CC libc/libgcc.libc.o
CC libc/rand.libc.o
CC libc/time.libc.o
CC libc/exec.libc.o
CC libc/readline.libc.o
CC libc/getopt_long.libc.o
CC libc/sysinfo.libc.o
CC libc/args.libc.o
CC libc/strlcpy.libc.o
CC libc/qsort.libc.o
CC libc/hexdump.libc.o
CC libc/die.libc.o
CC libc/coreboot.libc.o
CC libc/fmap.libc.o
CC libc/fpmath.libc.o
CC drivers/pci.libc.o
CC drivers/speaker.libc.o
CC drivers/serial/8250.libc.o
CC drivers/serial/serial.libc.o
CC drivers/i8042/keyboard.libc.o
CC drivers/i8042/mouse.libc.o
CC drivers/i8042/i8042.libc.o
CC drivers/cbmem_console.libc.o
CC drivers/mouse_cursor.libc.o
CC drivers/nvram.libc.o
CC drivers/options.libc.o
CC drivers/timer/rdtsc.libc.o
CC drivers/video/video.libc.o
CC drivers/video/vga.libc.o
CC drivers/video/corebootfb.libc.o
CC drivers/video/font8x16.libc.o
CC drivers/video/font.libc.o
CC drivers/video/graphics.libc.o
CC drivers/storage/storage.libc.o
CC drivers/storage/ahci.libc.o
CC drivers/storage/ahci_common.libc.o
CC drivers/storage/nvme.libc.o
CC drivers/storage/ata.libc.o
CC drivers/storage/ahci_ata.libc.o
CC drivers/storage/atapi.libc.o
CC drivers/storage/ahci_atapi.libc.o
CC drivers/usb/usbinit.libc.o
CC drivers/usb/usb.libc.o
CC drivers/usb/usb_dev.libc.o
CC drivers/usb/quirks.libc.o
CC drivers/usb/generic_hub.libc.o
CC drivers/usb/usbhub.libc.o
CC drivers/usb/uhci.libc.o
CC drivers/usb/uhci_rh.libc.o
CC drivers/usb/ohci.libc.o
CC drivers/usb/ohci_rh.libc.o
CC drivers/usb/ehci.libc.o
CC drivers/usb/ehci_rh.libc.o
CC drivers/usb/xhci.libc.o
CC drivers/usb/xhci_debug.libc.o
CC drivers/usb/xhci_devconf.libc.o
CC drivers/usb/xhci_events.libc.o
CC drivers/usb/xhci_commands.libc.o
CC drivers/usb/xhci_rh.libc.o
CC drivers/usb/usbhid.libc.o
CC drivers/usb/usbmsc.libc.o
CC drivers/hid.libc.o
AR /home/user/updates/coreboot/payloads/coreinfo/libpayload/libc.a
CC curses/keyboard.libcurses.o
CC curses/tinycurses.libcurses.o
CC curses/colors.libcurses.o
AR /home/user/updates/coreboot/payloads/coreinfo/libpayload/libcurses.a
CC arch/x86/rom_media.libcbfs.o
CC libcbfs/cbfs.libcbfs.o
CC libcbfs/ram_media.libcbfs.o
AR /home/user/updates/coreboot/payloads/coreinfo/libpayload/libcbfs.a
CC liblzma/lzma.liblzma.o
AR /home/user/updates/coreboot/payloads/coreinfo/libpayload/liblzma.a
CC liblz4/lz4_wrapper.liblz4.o
AR /home/user/updates/coreboot/payloads/coreinfo/libpayload/liblz4.a
AR /home/user/updates/coreboot/payloads/coreinfo/libpayload/libpayload.a
CC arch/x86/head.head.o.o
CP /home/user/updates/coreboot/payloads/coreinfo/libpayload/head.o
LPGCC coreinfo.bin
DEBUG coreinfo.debug
STRIP coreinfo.elf
CC+STRIP src/cpu/intel/fit/fit_table.c
HOSTCC cbfstool/cbfstool.o
HOSTCC cbfstool/cbfs_image.o
HOSTCC cbfstool/cbfs-mkstage.o
HOSTCC cbfstool/cbfs-mkpayload.o
HOSTCC cbfstool/partitioned_file.o
HOSTCC cbfstool/platform_fixups.o
HOSTCC cbfstool/cbfs_private.o
HOSTCC cbfstool/fsp_relocate.o
HOSTCC cbfstool/linux_trampoline.o
HOSTCC cbfstool/cbfs-payload-linux.o
HOSTCC cbfstool/compress.o
HOSTCC cbfstool/lz4.o
HOSTCC cbfstool/lz4hc.o
HOSTCC cbfstool/lz4frame.o
HOSTCC cbfstool/xxhash.o
HOSTCC cbfstool/lz4_wrapper.o
HOSTCC cbfstool/lzma.o
HOSTCC cbfstool/LzFind.o
HOSTCC cbfstool/LzmaDec.o
HOSTCC cbfstool/LzmaEnc.o
MAKE /home/user/updates/coreboot/vboot_lib/libvboot_host.a
vboot SHA256 built with tight loops (slower, smaller code size)
CC cgpt/cgpt_add.o
CC cgpt/cgpt_boot.o
CC cgpt/cgpt_common.o
CC cgpt/cgpt_create.o
CC cgpt/cgpt_edit.o
CC cgpt/cgpt_find.o
CC cgpt/cgpt_prioritize.o
CC cgpt/cgpt_show.o
CC firmware/2lib/2common.o
CC firmware/2lib/2context.o
CC firmware/2lib/2crc8.o
CC firmware/2lib/2crypto.o
CC firmware/2lib/2hmac.o
CC firmware/2lib/2kernel.o
CC firmware/2lib/2nvstorage.o
CC firmware/2lib/2recovery_reasons.o
CC firmware/2lib/2rsa.o
CC firmware/2lib/2sha1.o
CC firmware/2lib/2sha256.o
CC firmware/2lib/2sha512.o
CC firmware/2lib/2sha_utility.o
CC firmware/2lib/2stub.o
CC firmware/2lib/2stub_hwcrypto.o
CC firmware/lib/cgptlib/cgptlib_internal.o
CC firmware/lib/cgptlib/crc32.o
CC firmware/lib/gpt_misc.o
CC firmware/stub/tpm_lite_stub.o
CC firmware/stub/vboot_api_stub.o
CC firmware/stub/vboot_api_stub_disk.o
CC futility/dump_kernel_config_lib.o
CC host/arch/x86_64/lib/crossystem_arch.o
CC host/lib/chromeos_config.o
CC host/lib/crossystem.o
CC host/lib/crypto.o
CC host/lib/extract_vmlinuz.o
CC host/lib/flashrom.o
CC host/lib/fmap.o
CC host/lib/host_misc.o
CC host/lib/subprocess.o
CC host/lib21/host_misc.o
CC firmware/lib/tpm_lite/tlcl.o
RM libvboot_host.a
AR libvboot_host.a
HOSTCC cbfstool/cbfstool (link)
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/10/lto-wrapper
OFFLOAD_TARGET_NAMES=nvptx-none:amdgcn-amdhsa:hsa
OFFLOAD_TARGET_DEFAULT=1
Target: x86_64-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Debian 10.2.1-6' --with-bugurl=file:///usr/share/doc/gcc-10/README.Bugs --enable-languages=c,ada,c++,go,brig,d,fortran,objc,obj-c++,m2 --prefix=/usr --with-gcc-major-version-only --program-suffix=-10 --program-prefix=x86_64-linux-gnu- --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --libdir=/usr/lib --enable-nls --enable-bootstrap --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --with-default-libstdcxx-abi=new --enable-gnu-unique-object --disable-vtable-verify --enable-plugin --enable-default-pie --with-system-zlib --enable-libphobos-checking=release --with-target-system-zlib=auto --enable-objc-gc=auto --enable-multiarch --disable-werror --with-arch-32=i686 --with-abi=m64 --with-multilib-list=m32,m64,mx32 --enable-multilib --with-tune=generic --enable-offload-targets=nvptx-none=/build/gcc-10-Km9U7s/gcc-10-10.2.1/debian/tmp-nvptx/usr,amdgcn-amdhsa=/build/gcc-10-Km9U7s/gcc-10-10.2.1/debian/tmp-gcn/usr,hsa --without-cuda-driver --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=x86_64-linux-gnu --with-build-config=bootstrap-lto-lean --enable-link-mutex
Thread model: posix
Supported LTO compression algorithms: zlib zstd
gcc version 10.2.1 20210110 (Debian 10.2.1-6)
COMPILER_PATH=/usr/lib/gcc/x86_64-linux-gnu/10/:/usr/lib/gcc/x86_64-linux-gnu/10/:/usr/lib/gcc/x86_64-linux-gnu/:/usr/lib/gcc/x86_64-linux-gnu/10/:/usr/lib/gcc/x86_64-linux-gnu/
LIBRARY_PATH=/usr/lib/gcc/x86_64-linux-gnu/10/:/usr/lib/gcc/x86_64-linux-gnu/10/../../../x86_64-linux-gnu/:/usr/lib/gcc/x86_64-linux-gnu/10/../../../../lib/:/lib/x86_64-linux-gnu/:/lib/../lib/:/usr/lib/x86_64-linux-gnu/:/usr/lib/../lib/:/usr/lib/gcc/x86_64-linux-gnu/10/../../../:/lib/:/usr/lib/
COLLECT_GCC_OPTIONS='-v' '-o' 'build/util/cbfstool/cbfstool' '-mtune=generic' '-march=x86-64'
/usr/lib/gcc/x86_64-linux-gnu/10/collect2 -plugin /usr/lib/gcc/x86_64-linux-gnu/10/liblto_plugin.so -plugin-opt=/usr/lib/gcc/x86_64-linux-gnu/10/lto-wrapper -plugin-opt=-fresolution=/tmp/ccBOn8Xl.res -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lc -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lgcc_s --build-id --eh-frame-hdr -m elf_x86_64 --hash-style=gnu --as-needed -dynamic-linker /lib64/ld-linux-x86-64.so.2 -pie -o build/util/cbfstool/cbfstool /usr/lib/gcc/x86_64-linux-gnu/10/../../../x86_64-linux-gnu/Scrt1.o /usr/lib/gcc/x86_64-linux-gnu/10/../../../x86_64-linux-gnu/crti.o /usr/lib/gcc/x86_64-linux-gnu/10/crtbeginS.o -L/usr/lib/gcc/x86_64-linux-gnu/10 -L/usr/lib/gcc/x86_64-linux-gnu/10/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/10/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/10/../../.. build/util/cbfstool/cbfstool.o build/util/cbfstool/common.o build/util/cbfstool/cbfs_image.o build/util/cbfstool/cbfs-mkstage.o build/util/cbfstool/cbfs-mkpayload.o build/util/cbfstool/elfheaders.o build/util/cbfstool/rmodule.o build/util/cbfstool/xdr.o build/util/cbfstool/partitioned_file.o build/util/cbfstool/platform_fixups.o build/util/cbfstool/cbfs_private.o build/util/cbfstool/fsp_relocate.o build/util/cbfstool/fmap.o build/util/cbfstool/kv_pair.o build/util/cbfstool/valstr.o build/util/cbfstool/linux_trampoline.o build/util/cbfstool/cbfs-payload-linux.o build/util/cbfstool/compress.o build/util/cbfstool/lz4.o build/util/cbfstool/lz4hc.o build/util/cbfstool/lz4frame.o build/util/cbfstool/xxhash.o build/util/cbfstool/lz4_wrapper.o build/util/cbfstool/lzma.o build/util/cbfstool/LzFind.o build/util/cbfstool/LzmaDec.o build/util/cbfstool/LzmaEnc.o /home/user/updates/coreboot/build/util/vboot_lib/libvboot_host.a -lgcc --push-state --as-needed -lgcc_s --pop-state -lc -lgcc --push-state --as-needed -lgcc_s --pop-state /usr/lib/gcc/x86_64-linux-gnu/10/crtendS.o /usr/lib/gcc/x86_64-linux-gnu/10/../../../x86_64-linux-gnu/crtn.o
/usr/bin/ld: /home/user/updates/coreboot/build/util/vboot_lib/libvboot_host.a(2crypto.o): warning: relocation in read-only section `.rodata.vb2_sig_names'
/usr/bin/ld: warning: creating DT_TEXTREL in a PIE
HOSTCC cbfstool/ifittool.o
HOSTCC cbfstool/fit.o
HOSTCC cbfstool/ifittool (link)
Created CBFS (capacity = 9367012 bytes)
CBFS fallback/romstage
CBFS cpu_microcode_blob.bin
CBFS intel_fit
CBFS fallback/ramstage
CBFS vgaroms/seavgabios.bin
CBFS config
CBFS revision
CBFS build_info
CBFS fallback/dsdt.aml
CBFS fspm.bin
CBFS fsps.bin
CBFS vbt.bin
CBFS fallback/postcar
CBFS img/coreinfo
CBFS fallback/payload
CBFS payload_config
CBFS payload_revision
IFDTOOL
DD Adding Intel Firmware Descriptor
IFDTOOL me.bin -> coreboot.pre
Platform is: cnl
File build/coreboot.pre is 16777216 bytes
File 3rdparty/purism-blobs/mainboard/purism/librem_cnl/librem_14/me.bin is 3145728 bytes
Adding 3rdparty/purism-blobs/mainboard/purism/librem_cnl/librem_14/me.bin as the Intel ME section of build/coreboot.pre
Writing new image to build/coreboot.pre
IFDTOOL Unlocking Management Engine
Platform is: cnl
UPDATE-FIT set FIT pointer to table
UPDATE-FIT Microcode
CBFS coreboot.rom
FIT table:
Index Type Addr Size
0 Microcode 0xff7202f0 0x00000000
1 Microcode 0xff739af0 0x00000000
2 Microcode 0xff7532f0 0x00000000
CBFSLAYOUT coreboot.rom
This image contains the following sections that can be manipulated with this tool:
'RW_MRC_CACHE' (size 65536, offset 7340032)
'RW_SPD_CACHE' (size 4096, offset 7405568)
'COREBOOT' (CBFS, size 9367040, offset 7410176)
It is possible to perform either the write action or the CBFS add/remove actions on every section listed above.
To see the image's read-only sections as well, rerun with the -w option.
CBFSPRINT coreboot.rom
FMAP REGION: COREBOOT
Name Offset Type Size Comp
cbfs master header 0x0 cbfs header 32 none
fallback/romstage 0x80 stage 61368 none
cpu_microcode_blob.bin 0xf0c0 microcode 303104 none
intel_fit 0x59100 raw 80 none
fallback/ramstage 0x59180 stage 119776 LZMA (274656 decompressed)
vgaroms/seavgabios.bin 0x765c0 raw 28160 none
config 0x7d400 raw 765 none
revision 0x7d740 raw 735 none
build_info 0x7da80 raw 96 none
bootsplash.jpg 0x7db40 bootsplash 14565 none
fallback/dsdt.aml 0x81480 raw 14541 none
(empty) 0x84d80 null 36 none
fspm.bin 0x84dc0 fsp 581632 none
vbt.bin 0x112e00 raw 1182 LZMA (4608 decompressed)
payload_config 0x113300 raw 1728 none
payload_revision 0x113a00 raw 237 none
(empty) 0x113b40 null 612 none
fsps.bin 0x113dc0 fsp 190559 LZMA (212992 decompressed)
fallback/postcar 0x142680 stage 19496 none
img/coreinfo 0x147300 simple elf 54548 none
fallback/payload 0x154840 simple elf 69152 none
(empty) 0x1656c0 null 7882212 none
bootblock 0x8e9cc0 bootblock 20704 none
HOSTCC cbfstool/ifwitool.o
HOSTCC cbfstool/ifwitool (link)
Built purism/librem_cnl (Librem 14)
Then when I run the build with the coreboot_util.sh script, it says the build does not produce the reproducible build hash. Is that expected?
WARNING: Built coreboot image hash does not match expected reproducible build hash
Built: 4bd7...
Expected: 7b4621e5d0e5abb18bdb55a9692ee20e98d9e98a6db59e993d90856acbc2f0ff
