# apt-get dist-upgrade
python2.7 (2.7.15-4) wird eingerichtet ...
File "/usr/lib/python2.7/toaiff.py", line 51
table['sndt
����֊}�I�0)hs.Template()
SyntaxError: EOL while scanning string literal
E: Sub-process /usr/bin/dpkg returned an error code (1)
An EOL ( End of Line ) error indicates that the Python interpreter expected a particular character or set of characters to have occurred in a specific line of code, but that those characters were not found before the end of the line . This results in Python stopping the program execution and throwing a syntax error .
The SyntaxError: EOL while scanning string literal error in python occurs when while scanning a string of a program the python hit the end of the line due to the following reasons:
- Missing quotes
- Strings spanning multiple lines
Strings can’t normally span multiple lines. If you don’t want the string to appear on multiple lines but you want to initialize it on multiple lines (so you can read it more easily), you can “escape” the newline by putting a backslash before the newline. If you want it to appear on multiple lines, you can use triple quotes around the string.
