Qubes 4.0 Missing Wifi Drivers
I installed Qubes OS, on a Dell e6330. I have a dual band wifi card, with an Atheros chip set. It appears that the wifi driver was not installed. Has anyone else had this problem; and is there a fix?
Also, can I purchase Qubes on a USB stick, alacarte; and will it have the wifi drivers installed?
PS, I like the idea of the Qubes OS; and want to become familiar with it before using it on a Librem.
to be honest i don’t need qubesOS for daily rutine so i can’t help you.
You should try contacting the team from qubesOS or have a look here first >>
