I’m having trouble getting network connections to pass thru to any of the Qubes stand alone VMS, regardless of the OS.
Qubes users, have you been able to get stand alone VMS to access the network on Purism hardware?
If so, how did you do it?
UPDATE:
Got it working.
Here’s what did the trick:
Manual network setup.
Use IPV4.
Be sure you’re entering the exact network details Qubes created for the VM. Use the Qubes manager and then go to Qube settings to get those details.
Be sure to turn off “Make available to others”. (At least that seems to be what finally got it working on this end.)
