The Wiki says that the Librem Key is mandatory.
Wouldn’t it be possible to use a phone TOTP such as Authy/Google Authenticator for the anti-tampering verification and save the GPG keys somewhere else (such as existing Yubikey) as a backup, for the Librem 15v4?
IIRC the Heads project supports TOTP token generation via the TPM, so I wonder if it will be possible
to test PureBoot without the Librem Key and if such setup was tested or documented anywhere.
Our PureBoot builds are configured specifically to use the Librem Key instead of another device for TOTP. There’s no fallback to other methods if a Librem Key is unavailable. You’d need to recompile the firmware with the Librem Key config option removed.
I don’t want to hack around it since it means I will have to re-do this process upon every upstream
update, while also ensuring it doesn’t break anything else on the way…
Doesn’t sound like a fun task, it’s unfortunate since I already have Yubikey implemented in my ecosystem
so switching to Nitrokey will require some changes as well.
Do you plan to implement alternative TOTP methods in the future?
