Question About PureOS Apt Sources
The first time that I put my Librem 5 USA (Liberty) online, the first action I did was to open Terminal app to run:
sudo apt-get update
But the first time that I ran the command, it gave a ton of errors indicating that Certificate verification failed: The certificate is NOT trusted. The certificate chain uses expired certificate. Could not handshake: Error in the certificate verification. [IP: 49.13.57.135 443]
Then, I ran the command a second time and it worked fine.
Is this any kind of security issue or is this expected? Was my device just slow to refresh a certificate cache?
Two possibilities I can think of:
  1. one server had out of date certificates
  2. your phone had not yet synchronized its clock so ssl validation failed as a result
I decided that I think the problem was probably the clock not yet being synchronized like you said, so I have not bothered to investigate this issue further. Thanks!
