Hi everyone, hopefully this help request isn’t too much trouble. I have a less than one year old 15v4 that usually sits on a desk. A couple of days ago I moved it and noticed a rattle inside the machine. I had some time to investigate today and found a small loose screw. The only vacant hole I could find was on the board near the hinge. Can anyone verify that this indeed is the correct screw placement?
Four photos attached.
Thanks for your help!
