How do I clear this out? The input sources settings reference the keyboard shortcuts settings. I’ve already removed the two input source change shortcuts, which weren’t set to <Alt>-<Shift>
to begin with anyway. I’m an Emacs user and this is super annoying.
Do you have multiple input sources, or are you experiencing issues even with only one?
In GNOME Tweaks->Keyboard and Mouse, is “Show Extended Input Sources” set to on or off?
I didn’t notice anything weird in the PureOS VM I have, but I’m not sure if I’d be able to reproduce it there or not.
I use US English with Dvorak, and keep Qwerty around as a courtesy to others.
I just turned on Extended Input Sources. No change. (Though I did see the Emacs keyboard shortcuts settings. Turned it on. Thanks for that!)
What’s weird is that the Languages settings specifically reference <Alt>-<Shift>
being set in the Keyboard settings for shortcuts, and it’s there with a default of a different shortcut.
Ah, nice find. Glad you got it resolved!
