Purism typically uses DHL for international shipments and when I check DHL’s calculator (https://www.dhl.com/us-en/home/get-a-quote.html), it seems shipping an A4 envelope to Berlin, Germany is over $100. Maybe I entered the details incorrectly for a L5 back cover but it seems you are getting a lower rate?
Ok I’m trying to find an online 3D Printing service to print your cover but it seems it’s harder than I expected!
That’s my request:
I would really appreciate if you could print the back cover for my Librem 5 smartphone, manufactured by Purism. Unfortunately, the original one broke (it’s a known defect).
I’m attaching two files (1a and 1b). This is a “dual-part” design: file 1a is the main shell with a decorative hole, while file 1b is the insert that fills that hole.
Here are my specifications:
File merging: I’d like the two files to be merged during the slicing process to create a single, solid, uniform piece. I do not want the decoration (penguin) to be visible or a different color: the final result must be a smooth, continuous black surface.
Material: I strictly require TPU (recommended hardness 98A). The case must be flexible so it can be removed and repositioned hundreds of times without the hooks breaking (which would happen with PLA or ABS).
Color: Black.
Infill: I suggest a high infill (at least 50–80% or thick walls) to ensure that the reinforced edges (bump corners) are solid.
I look forward to receiving a quote and delivery timeline.
Thank you
And here what one of the sellers answered me:
Unfortunately, the areas where the wire passes through the corners aren’t built to last; if 3D-printed, they might have aesthetic and functional flaws and would be significantly less reliable than the original.
Furthermore, the Linux penguin emblem aligns perfectly with the recess in the main body, so if placed side-by-side during printing on a smooth surface (so to speak, since in filament 3D printing it’s never truly smooth), it disappears completely or almost entirely. Additionally, it must be entirely black, so it would be completely invisible.
Finally, the small side notches for the interlocking joint are too small for FDM printing technology and cannot support the functional load of the joint itself, while the walls are too steep for 3D printing with TPU.
Therefore, unfortunately, the manufacturing process could result in an unusable part.
Please what do you think about it? Is it the salesperson’s incompetence?
Here what another seller answered me: “It would cost somewhere between 100 and 120 euros. You’d have to do a few test runs, and there’s no guarantee the smartphone will fit right the first time. Maybe there are specialized companies that can do it for less.
Is it so difficult to find a reliable and accessible cost 3d printing to have my L5 cover?
On the first one: If “the wire” refers to the holes in the corners, those are not the weak point. You can disregard that. The corners are as sturdy as printing allows, which is to say enough for normal use but may brake in certain situations. These are not to be confused with parts made with other techniques. Seems silly to compare to original - especially since there the original is printed too. I’ve had a single corner snap off (the cover still remained in place since it fits so well, based on the original design files): it did so cleanly and a touch of acrylic quick dry glue fixed that. But I also fully expect that, as it’s 3D printed and the mechanic involves bending it, I’ll have to print another one at some point. That’s the whole point, easy to replace.
And by the way “emoved and repositioned hundreds of times without the hooks breaking (which would happen with PLA or ABS).” seems a bit excessive expectation. Certainly the design was not intended to be at that level. The act of forcing and bending any plastic is likely to cause damages over time, and eventual failure. And it’s easy to overbend and snap a corner off (“exceed reasonable structural design limits”) as there is leverage there (tip: pushing more downwards and bending the whole back is safer than bending just the corner in a sharp angle). Well, mine is from PLA.
The penguin is a quick design and the plecement may vary with different technology printers, I suppose. It worked with Cura (no special settings) and dual extrusion Ultimaker S3 (hobby quality). If you print using only one color, it will of course disappear (I think one of my pics shows that too, in white). Some may prefer that. It was never designed to show up as an emblem in monocolor. Interesting idea though.
On the third part I have no idea what kind of printers they have. I only know the hobby printer I used did ok job. Maybe they just don’t what to risk making a bad or ok one?
Wow. I suppose they are right - it’s their equipment and time. It cost me a fraction of that, printing it at the library. Maybe you can find a hobby group or hacklab community near by…? A used hobby printer may be available at the price of a couple of those prints…
[Just out of curiosity, can you give some general location, where are you?]
I am writing this from mobile on a Librem 5. Still using the “perfect” backplate mentioned on this thread 40 posts earlier, in case that is a useful data point.
I’m in Italy
It’s probably a reasonable choice, if you use a pro printer that can do the detail, and what that same plain backplate. The cornered model that I did is more forgiving about the finest details and will hold on better due to the structure, plus offers some additional protection, and possibly that penguin. I think we should have a larger selection of backplates with different images or something for more variation/personification.
There are a at least a few there too: Making sure you're not a bot! - maybe one is near you..?
Finally I found a 3d print service that for a reasonable price, 20€ ≈ 20$, delivery cost included!!, printed and sent to me the cover!! I took several pictures, outside at sun and inside home so you can have the best idea about it! It fit ok, but it seems to be not too solid (I can hear clicks when I press the small teeth into Librem 5 holes, let me call it, but it’s too soft in my opinion)! Honestly AI suggested me to use TPI 98 that’s better, more solid but I didn’t find it (every company uses TPI 95). Moreover the corners are too small screen side! In case of falling down I’m not sure how much they could protect it. Unfortunately I’m not able to modify CAD files but someone of you could, please, do that? I prefer to have them bulkier but more protective than like now they’re! Maybe it would be nice to have, for example, file_s for small and file_b for big corners, what do you think? I’m pretty sure that it’d take very small time to modify them! Maybe also making the clicks better (but not sure if it depends by the CAD project itself or the printing: some company refused to print it because “too small so too much imprecise”)!
I’d like to know your impressions, thank you!
Surely I’ll continue to looking for TPU 98 and maybe better/improved CAD project here but, finally, I don’t have to run to find it because I can use this one in the meanwhile!
Lastly, they also sent to be two rigid plastic covers, one black with Pingu (not shown in the official one as I requested) and one gold. No idea why they did it ![]()
Thank you
Some of the print details look very good, but the warping is odd - was not expecting that (it’s from too soft material or a failed print?). I’m not sure how the model should behave with TPU, as I’ve only experimented with PLA. Yes, the small notches along the long edge are very finicky, which is why the corner “claws” are more likely to keep the cover in place - part of the whole idea. The rigid (gold) seem like they should work perfectly (overall print quality seems better than mine).
I get your point about the corners having more on the screen side, a larger bump to that direction. I’m indeed leaning more towards more subtle approach on that as it makes the whole thing thicker when fitting to a belt pouch. But yes, it’s relatively easy to add a couple of mm of height to those. Unfortunately I don’t have access to that file and app for now but it’s easily done. Just give some pointers on the general shape and size. If you’re not using the penguin, I take it that can be left off the design?
The gold one is interesting. I wonder if it was just a test or if they are trying to entice you to get alternative colors. Did it make your phone look funny at least - like one of those luxury models? ![]()
I made some extra ones of my own.
Interestingly, I noticed that while the printing is rather precise (for what it is), with such thin layers (there’s only few of them on the back cover flat parts), although they feel solid, they actually are more like “weaved”, as you can see light pouring through against a lamp. The amount and size of the holes depends on how fine the printer is able and configured to do, and the priting method. I’m tempted to call this an accidental positive feature: 3D printed covers have inherent micro channels for heat dissipation
JR-Fi, thank you so much for your detailed feedback and for being so available to help!! ![]()
About the warping: honestly I’m not sure either. The TPU 95 they used feels quite soft, so maybe that’s the main reason? The print itself looks clean in the small details, so I don’t think it’s a “failed” print per se, but the overall shape is a bit bent as you noticed. I suspect a stiffer TPU 98A would hold its shape better. I’ll keep looking for a service that offers it!
About the corners: what I had in mind is something like adding 2–3 mm of extra height on the screen side, especially at the four corners. The shape could be a gentle rounded bump, not a sharp edge, so it doesn’t feel uncomfortable in the hand. The idea is simple: if the phone falls face-down on a flat surface, the screen shouldn’t touch the ground. I understand your concern about the belt pouch though! That’s exactly why I suggested the two-file approach — file_s (current, slim) and file_b (bigger, more protective) — so everyone can pick what fits their use case. No rush at all, whenever you have access to the CAD files!
About the penguin: yes, absolutely, you can leave it off! As I mentioned in my original request, I want a completely smooth and uniform black surface, so the penguin is not needed for me at all. If removing it also simplifies the print and reduces potential issues, even better! ![]()
About the gold one: haha yes it actually looks quite funny! My Librem 5 suddenly looks like a VIP luxury edition
I really have no idea why they included it — maybe they had some leftover gold filament and used it as a bonus test print? But the quality is surprisingly good, as you noticed. Honestly the rigid black one with the penguin is also quite nice, even if I didn’t ask for it! As you can see, this one fit much better and stronger than TPU! It seems, also, a little bit smaller, right?
Thank you again for your work on this project and for being willing to modify the files. It really means a lot, not just to me but to the whole L5 community! Let me know if you need any more details about the corner shape, dimensions, or anything else. I’ll try to take some close-up photos of the corners against a ruler if that helps!
Modified it a bit. Now there are extra bumps, about 2,5mm, and it’s easy to sandpaper or carve a bit off if you need to adjust. Also removed penguin and some details from the edges (the mini “claws” that the original cover used to attach) so that making those won’t cause any abnormalities (however, it was a bit quick and rough, so I’m not sure how those fixes effect the end result). Also added small extensions to the old peel corner (the slot to open the cover), to cover small missing frame edges.
The .stl file for printing is at Add new directory for community designed 3D-printable files (!6) · Merge requests · Librem5 / hw / 3D_designs · GitLab
[And with respect, apologies to the designer of the original back cover
For my loved Librem 5 i demand a ninja-case like n9.
I strong wont accept anything others than a ninja.
Please just your advice about this new one: PLA or TPU? ![]()
It’s still made with PLA or other more rigid (than TPU - or it needs to be rally hard TPU, maybe?) plastic in mind.
I suppose with some alterations it could be made more TPU friendly, more rigid structure (the main issue is probably that the corners need more/higher support along the long edges, but this is just speculation since I can’t test that theory - it’s easy to make it thick, its harder to make it just thick enough without making it look big and bulky).
