bouncing and slow throughput of repo.puri.sm & arm01.puri.sm.
a download from Ubuntu.com went fine.
does anybody else experience the same?
as of today:
purism@pureos:~$ sudo apt install libshairplay0
Reading package lists… Done
Building dependency tree… Done
The following packages were automatically installed and are no longer required:
dleyna-server gir1.2-totem-1.0 gir1.2-totemplparser-1.0 grilo-plugins-0.3 libdleyna-connector-dbus-1.0-1 libdleyna-core-1.0-5 libdmapsharing-3.0-2 libgrilo-0.3-0 liboauth0
libtotem0 python3-xdg
Use ‘sudo apt autoremove’ to remove them.
The following NEW packages will be installed:
libshairplay0
0 upgraded, 1 newly installed, 0 to remove and 3 not upgraded.
Need to get 99,4 kB of archives.
After this operation, 214 kB of additional disk space will be used.
Err:1 Index of /pureos/ byzantium/main arm64 libshairplay0 arm64 0.9.0~git20180824.096b61a+dfsg1-2
Could not wait for server fd - select (11: Resource temporarily unavailable) [IP: 138.201.228.45 443]
E: Failed to fetch https://repo.pureos.net/pureos/pool/main/s/shairplay/libshairplay0_0.9.0~git20180824.096b61a%2Bdfsg1-2_arm64.deb Could not wait for server fd - select (11: Resource temporarily unavailable) [IP: 138.201.228.45 443]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?ak@mi:~/librem5/librem5-flash-image$ sudo ./scripts/librem5-flash-image
[sudo] password for ak:
2023-05-09 15:25:02 INFO Looking for librem5r4 plain byzantium image
2023-05-09 15:25:08 INFO Found disk image Build 14282 ‘plain librem5r4 byzantium image’ from Tue May 9 01:04:58 2023
2023-05-09 15:25:10 INFO Found uboot Build 85 from Thu Aug 25 15:22:41 2022
2023-05-09 15:25:10 INFO Downloading to ./tmp_librem5-flash-image_gokh9_h_
2023-05-09 15:25:11 INFO Downloading image from https://arm01.puri.sm/job/Images/job/Image%20Build/14282/artifact/librem5r4.img.xz
Download: 2%|██▍ | 14761984/896778472 [00:39<51:28, 285617.29it/s]2023-05-09 15:25:52 INFO Connection error, retrying | 62482766/4500000256 [00:39<4:16:44, 288070.08it/s]
Download: 8%|███████████▌ | 70729546/896778472 [01:45<06:46, 2032087.85it/s]2023-05-09 15:26:57 INFO Connection error, retrying | 152799494/4500000256 [01:45<32:09, 2252527.13it/s]
Download: 11%|███████████████▎ | 94331802/896778472 [02:32<10:34, 1264440.12it/s]2023-05-09 15:27:44 INFO Connection error, retrying | 601875064/4500000256 [02:31<13:53, 4677984.83it/s]
Download: 11%|████████████████▋ | 102770576/896778472 [02:55<16:10, 818529.91it/s2023-05-09 15:28:08 INFO Connection error, retrying | 650852829/4500000256 [02:55<12:10, 5268219.05it/s]
Download: 14%|████████████████████▊ | 127646447/896778472 [03:44<14:39, 874126.05it/s]2023-05-09 15:28:57 INFO Connection error, retrying | 783975296/4500000256 [03:44<14:24, 4296791.58it/s]
Download: 52%|████████████████████████████████████████████████████████████████████████████ | 470497561/896778472 [06:18<04:08, 1717473.93it/s2023-05-09 15:31:31 INFO Connection error, retrying██████████████████████████████████████████████████████████████ | 3052688604/4500000256 [06:18<03:57, 6086018.27it/s]
Download: 54%|██████████████████████████████████████████████████████████████████████████████▊ | 487106998/896778472 [06:46<03:24, 2004510.65it/s]2023-05-09 15:31:58 INFO Connection error, retrying██████████████████████████████████████████████████████████████▉ | 3113967805/4500000256 [06:46<03:08, 7346317.10it/s]
Download: 71%|███████████████████████████████████████████████████████████████████████████████████████████████████████▍ | 640098859/896778472 [09:00<01:53, 2252156.88it/s2023-05-09 15:34:12 INFO Connection error, retrying███████████████████████████████████████████████████████████████████████████████████▏ | 3718780379/4500000256 [09:00<04:22, 2975841.91it/s]
Download: 73%|█████████████████████████████████████████████████████████████████████████████████████████████████████████▉ | 655019750/896778472 [09:29<01:58, 2046959.13it/s]2023-05-09 15:34:41 INFO Connection error, retrying███████████████████████████████████████████████████████████████████████████████████ | 3746103830/4500000256 [09:29<04:12, 2989396.44it/s]
Download: 79%|██████████████████████████████████████████████████████████████████████████████████████████████████████████████████▏ | 706350587/896778472 [10:33<03:06, 1020182.23it/s2023-05-09 15:35:45 ERROR Max connection errors reached, aborting████████████████████████████████████████████████████████████████████████▎ | 3842696140/4500000256 [10:33<00:57, 11485263.97it/s]
2023-05-09 15:35:45 INFO Cleaning up.
File “/home/ak/librem5/librem5-flash-image/./scripts/librem5-flash-image”, line 537, in
sys.exit(main())
File “/home/ak/librem5/librem5-flash-image/./scripts/librem5-flash-image”, line 509, in main
download_image(urljoin(image_ref[‘url’], ‘artifact/{}.xz’).format(IMAGE.format(board)),
File “/home/ak/librem5/librem5-flash-image/./scripts/librem5-flash-image”, line 208, in download_image
for data in stream:
File “/home/ak/librem5/librem5-flash-image/./scripts/librem5-flash-image”, line 153, in resuming_stream
raise PrematureEndException()
main.PrematureEndException
