Repos for PureOS Crimson and PureOS Byzantium unavailable
Unable to update PureOS on L11 and L5, assuming it’s like the other times that this occurred…
Message shown is: Release file for https://repo.pureos.net/pureos/dists/byzantium/InRelease is expired (invalid since 7h 28m 47s). Updates from this repository will not be applied.
@irvinewade @JCS can we get some context?
Also put in a support ticket.
I received the same message when running sudo apt update in Terminal. Did you get a resolution to this issue?
Same is true for landing and dawn, basically every repo.
Ok same problem for me, same message on terminal :
Release file for https://repo.pureos.net/pureos/dists/byzantium/InRelease is expired (invalid since 3d 7h 5m 36s). Updates from this repository will not be applied.
3 days with out update :slight_smile:
It’s strange that it takes so long to repair
Same problem.
“Release file for https://repo.pureos.net/pureos/dists/byzantium/InRelease is expired”
as of just now: (invalid since 3d 11h 10min 49s)
No, the release files for all repos are not valid… Waiting on their end to redo the release files (or whatever they need to do on their end to allow it to work…
Resolved:
