Repositories expired?
For some hours it says now:
purism@pureos:~$ sudo apt update
Get:1 https://repo.pureos.net/pureos byzantium InRelease [9,641 B]
Get:2 https://repo.pureos.net/pureos byzantium-updates InRelease [9,649 B]
Get:3 https://repo.pureos.net/pureos byzantium-security InRelease [9,650 B]
Reading package lists... Done
E: Release file for https://repo.pureos.net/pureos/dists/byzantium/InRelease is expired (invalid since 3h 48min 57s). Updates for this repository will not be applied.
E: Release file for https://repo.pureos.net/pureos/dists/byzantium-updates/InRelease is expired (invalid since 3h 54min 42s). Updates for this repository will not be applied.
E: Release file for https://repo.pureos.net/pureos/dists/byzantium-security/InRelease is expired (invalid since 3h 52min 38s). Updates for this repository will not be applied.
We have had this already in the past, but not for so much time.
Maybe an expired certificate or a DST issue? :confused:
Same for me!
indeed… making this longer then 10 char
Occurs for me as well
8 hours in, also canĘĽt update from the repository.
I can also confirm for Crimson on AMD64:
sudo apt update && sudo apt upgrade -y
E: Release file for https://repo.pureos.net/pureos/dists/crimson/InRelease is expired (invalid since 8h 22min 15s). Updates for this repository will not be applied.
E: Release file for https://repo.pureos.net/pureos/dists/crimson-security/InRelease is expired (invalid since 8h 27min 42s). Updates for this repository will not be applied.
E: Release file for https://repo.pureos.net/pureos/dists/crimson-updates/InRelease is expired (invalid since 8h 27min 42s). Updates for this repository will not be applied.
Figured it was affecting all of Byzantium
I suspect it affects landing and octarine as well, alongside the debug variants.
What could be the cause you think?
The errors are clear:
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA256
Origin: PureOS
Suite: crimson
Version: 11
Label: PureOS 11.x (crimson)
Date: Mon, 25 Mar 2024 08:22:30 -0000
Valid-Until: Tue, 02 Apr 2024 08:22:30 -0000
Acquire-By-Hash: yes
Architectures: all amd64 arm64
Components: main
Hash: SHA256
Origin: PureOS
Suite: crimson-security
Version: 11
Label: PureOS 11.x Security Updates
Date: Mon, 25 Mar 2024 08:17:03 -0000
Valid-Until: Tue, 02 Apr 2024 08:17:03 -0000
Components: main
Hash: SHA256
Origin: PureOS
Suite: crimson-updates
Version: 11
Label: PureOS 11.x Bugfix Updates
Components: main
I do not know why they are not being renewed, but if there is an urgent need to update packages, you can change the date and time.
Since this is related to it affecting all current PureOS variants, I think this topic should be edited to be a PureOS issue instead of Librem5
When rolling back the date and time on Byzantium, I’m seeing a message about the IP not being found for Index of /pureos/ byzanium-security
As an error in certificate for the IP 49.13.57.135:443
Pinging the IP results in 100% packet loss. I’m assuming the repo servers are down to fix the issue…
Hi everyone! The repository was not updating for a few days because a SSL certificate expired on a server that the system has to query while building the repository metadata. For some reason, our monitoring did not pick that up (we will find out why), and Laniakea is logging the error but does not send a very visible notification - yet. I will change that now, to ping us on Matrix if that ever happens again.
I also reconfigured certbot again, this time automatic renewal should not fail.
We are very sorry for the inconvenience, and the metadata should be fully up to date again in a few minutes.
Best,
Matthias
Hi, I updated this morning and it came down a new kernel. On rebooting it, I got nearly a heart break when I saw the message “crypsetup…” for minutes until the boot continued with success. Don’t know what the L5 was doing.
installed a new kernel so you just wait and it should boot up, might require two reboots I noticed. It froze on the second reboot for me at login screen. Third did the charm.
Myself, after this morning’s update I find the touchscreen unresponsive at “Enter disk decryption passphrase” screen, same as described in this post from 2 years ago: Anyone experience an issue with the latest update?
Would anyone know if the same solution from that thread works again now? I’m pretty close to giving up on telephony in general! :grimacing:
Better asking in the right thread: Can't turn on after latest update (kernel), no response to touch input, USB keyboard not working
(No worries, your post was first, but collecting same issue together. :slight_smile:)
That’s no fun. There’s no reason I can see that it wouldn’t work, but there may be an easier way. My problem came about in a weird way, because the drive wasn’t partitioned right, so the fix necessary was probably more complicated than a normal corrupted file or something. It might be good to see if your problem came about for the same reason. Have you installed uuu and connected via jumpdrive before? There’s a way to replace some of your boot files that way:
I’d try fixing by replacing those files first. In any case, I’d check for freespace on your partitions to make sure it doesn’t happen again. I understand they implemented a fix to prevent the issue from happening due to a filled up boot drive, but it didn’t stop mine due to a filled up root drive. Fixing the partition prevented it from reoccurring.
