Didn’t I search correctly or there is no question about this?
I scaled the display to 125% but I do have a major issue with the keyboard as didn’t scaled automatically and more or less is unusable.
Is it there a way to scale (up) the keyboard?
Use a custom Squeekboard layout that supports 125% scaling:
Wow … nice work there @Ick
thank you for sharing this
@FranklyFlawless: @Emma is the expert for Firefox CSS and does not know much about Squeekboard and GTK stuff, as far as I know. She just helped me out with an install script to make it easier for people to apply or remove the change.
@dallas87: Don’t hesitate to ask if you still have some questions. And by the way glad to read that someone is really interested in 125% scale - I thought that’s maybe the only one nobody would use. ![]()
I’m interested but I founded an issue with it
On web, sms (some other places where I tried it) the keyboard seems to be fine but on terminal it will scale down automatically, so it is hard to use the keyboard when using terminal
Which one do you use exactly? I will check if there is a bug. And are you sure that you installed the terminal keyboard as well? It is located in ~/..local/share/squeekboard/terminal. Please open the file that’s inside this folder (if there is any) and tell me the number of the line default: ( with: ...
sorry for that, you’re right
I didn’t installed for terminal as well. it is ok ![]()
