I have a Librem 13v2 and want to fit a TPM, any one know where to get a suitable module and what spec i should be asking for?
There is a similar question that was asked once and short of it was that Todd responded with: if you have the laptop from before when TPMs where added then the mainboard isn’t equipped (i.e. has no slot prepared) for it.
So unless you are or know a really good hardware engineer and have a lot of patience with iron soldering there is not much you can do unfortunately I think
thought so, thanks for the help
I also have a 13 v2. Will it be possible to order just the motherboard (with the updated TPM slot and TPM), and install the motherboard myself into a 13v2 chassis?
