Running PostmarketOS on My Librem 5
Well, that was unexpected…
Running “sudo apt-get install ./librem5_2022.10-librem5.1_arm64.deb“ from the L5 terminal, context “Downloads” directory, I got:
E: Unsupported file ./librem5_2022.10-librem5.1_arm64.deb given on commandline
“ls” does show the file there.
Try apt instead of apt-get ?
I just double checked this at my end, downloaded the file ran sudo apt-get install ./u-boot-librem5_2022.10-librem5.1_arm64.deb and it installed just fine, no complaints, warnings or errors. Perhaps the file was corrupted during transmission, try redownloading.
In case it helps, I just downloaded it.
sha256sum: 5eebaee15d76ec0707d3d093ec1b97fa26076e44b4e80c5a18b0dd7deca2be28
Do those match for you?
This looks like an error on my part, I did not provide the full file name in the example code I gave previously.
the command should be…
note the “u-boot-" in front of the previously used file name.
Did… same.
Not corrupted… I missed the first part (u-boot_) in my copy/paste. :man_facepalming:
.deb installed…
Flash complete…
Booting from SD…
Success! I got CRIMSON! :collision: :joy:
You guys ROCK!
:folded_hands:
@Loki is incredible.
Not that you are worried now but that is a fairly terrible error message then. I presume this is a case of Software Stack Error Burial. Some routine deep inside some library knows what the actual error was (presumably errno ENOENT 2 No such file or directory) but by the time it percolates up to the top of the software stack all useful detail is gone. :frowning:
get a cheap used motorola and install iodéOS on it for banks and etc.
I do have an intel mac bu it is failing, I have got a mac mini m1 and for now would like to be flash the phone from that. I have heard of homebrew but never needed it before, if you could share the guide for this option that would be great.
I’ve never used apt-get to install a .deb file, but I have used dpkg -i to do so many times. No idea whether that would work in this case.
I have provided a rough guide below, this is taken from my notes from going through this process on macOS Sonoma a little while back, I’m not aware of any changes to newer versions that would require additional steps, but if you do encounter any problems note down the exact error message(s) and let me know.
I have assumed that you have little to no knowledge/experience of working within the Terminal so apologies in advance if this is not the case.
The quick overview of the steps are…
  1. Install Homebrew package manager (which will install Command Line Tools for Xcode as part of it process)
  2. Install uuu
  3. Download the librem5-flash-image script
  4. Install the librem5-flash-image script Python module dependencies
  5. (Optionally) Install librem5-flash-image script
  6. Go flash
There are some additional minor operations throughout the process (creating directories etc,.) but I think it’s reasonably straightforward. Everything will be done from the command line within a Terminal window so open the Terminal application from either Finder → Applications → Utilities → Terminal or Launchpad → Other → Terminal
First, Install Homebrew, the install process will make a number of checks including whether or not sudo is available so you may be prompted to enter your user password. The installer will then present the details of everything it will be doing and will wait for you to confirm by pressing enter. From the terminal, enter the follwoing install command…
/bin/bash -c "$(curl -fsSL https://raw.githubusercontent.com/Homebrew/install/HEAD/install.sh)"
Hopefully the install completes without errors, note the last few lines of output, it is likely to ask you to enter a few lines of code into the terminal, the lines add the package manager to the terminal environment and are required, the lines are likely to start with echo or eval, each line should be entered separately.
Optionally turn off Homebrew’s analytics by entering brew analytics off
Next, install uuu
brew install uuu
Next, create and change into a direcotry where the librem5-flash-image script will be downloaded and stored.
mkdir -p ~/.tools/librem5
cd ~/.tools/librem5
Next, download the librem5-flash-image script code repository
git clone --depth 1 https://source.puri.sm/Librem5/librem5-flash-image.git
Next, change into the script repository directory and install the librem5-flash-image script dependencies (Python modules). You will see some warning messages (one for each module being installed) regarding the modules being installed in a location outside of your PATH, these can be safely ignored, you may also see a notice about an newer version of pip being available, this can also be safely ignored.
cd librem5-flash-image
pip3 install -r requirements.txt
Optionally, install the librem5-flash-image script, this is not an absolute requirement but by installing/linking the script to a location in your PATH (/usr/local/bin is in the PATH by default) you can envoke the script without having to specify the path to the script or as most do, be in the same directory as the script. Using sudo here, you may be prompted for your user password.
sudo install -m 755 -d /usr/local/bin
sudo ln -s $(pwd)/scripts/librem5-flash-image /usr/local/bin/librem5-flash-image
exec zsh
Everything you have done so far installs and sets up all the tools/utilities required to flash the Librem 5 from within macOS, the set up is now done, the above steps do not need to be repeated for subsequent flashing operations.
You are now ready to flash, as mentioned earlier in the thread, I do this as a two step process, I first download the files using librem5-flash-image then I flash the Librem 5 using uuu directly. This is due to uuu requiring to be envoked with elevated privileges so to download and flash in a single operation requires envoking librem5-flash-image with sudo and I prefer to limit my use of sudo to the minimum.
You have some options (you should refer to official documentation for all options) when it comes to which image you flash to the Librem 5, you can choose an encrypted image (LUKS) or plain by adding --variant LUKS or --variant plain respectively you can choose to install the current testing/alpah release (crimson) by adding --dist crimson omitting the --dist argument will cuase the script to choose the latest build of the current release (byzantium), you can add --stable to choose the current stable build of the current release. I am choosing to use the encrypted (LUKS) variant of the testing build (crimson) here
librem5-flash-image --dir ~/Downloads/Librem5/images/crimson/alpha --skip-flash --skip-cleanup --variant luks --dist crimson
Next, change into the directory where the files have been downloaded and flash the Librem 5 with uuu, you can choose to put the Librem 5 into download mode either before or after envoking uuu it doesn’t matter (refer to the Reflashing guide you linked to previously for instructions to set the Librem 5 into download mode). Note that during the flashing process the Librem 5 changes it’s USB device identity so your machine may ask you if you want to allow access to device twice, the phone should reboot once the flashing process completes. Before envoking uuu I would resize the terminal window, at least increase it’s width, it not absolutely required, however, the current release version of uuu has an issue which will result in it throwing an exception when run in a terminal of default width (80 characters), it doesn’t affect the flashing process but does throw a notice error and ends up producing a lot of output which, if you’re not expecting it, can be a little disturbing.
cd ~/Downloads/Librem5/images/crimson/alpha
sudo uuu flash_librem5r4.lst
The Librem 5 should now be flashed with it’s new image, you can choose to keep the downloaded images files or remove them, if removing them, change out of the directory and remove it
cd ~
rm -rf ~/Downloads/Librem5
Thank you @Loki, following this guide I have flashed my phone from my mac mini m1!
My phone had byzantium and I flashed it to crimson then back to byzantium then back to crimson ha ha. Then with the first guide I flashed it to postmarketos.
I have flashed my phone a few times before but with help from a friend who knows more about linux than I do and I had to use their pc too, this is way easier than what I was doing so thank you again. I have used the terminal before but not much and with help so the detail you shared is very helpful.
I did see some warning when installing the python modules like you said, there were a lot should I be worried about them?
I used pmbootstrap to build my current installation of postmarketos. I think that in the process, I might have accidentally omitted the GPS module. I currently appear to have GPS working. Pure maps works to show my current location on the map. But there is nowhere in the settings to configure, or turn on and off GPS. Does anyone else here have a missing settings GUI for GPS in postmarketos?
In this case, the warnings can be safely ignored. You should only see the warnings when installing the modules, if I’m recalling the warning correctly it just means that you wouldn’t be able to call the module directly. These modules are called, imported or referenced from within the librem5-flash-image script when run through Python and Python should be able to locate the modules without them being on/in the PATH.
I should note that if you followed the guide and installed the modules with the same pip3 install … command then the modules will be installed for the user that installed them so if you log in under a different username then you would have to install those modules again under that user if that user also wanted to use the librem5-flash-image script. The alternative is to install the modules globally (a.k.a “site-wide”) so all users would be able to use them without having to install their own copies individually, my preference tends to lean towards installing most modules for individual users as was done in guide.
Thank you for posting this. It flashed for me. There were some niggling issues, but using the Librem5-flash-image script is a seamless way to go. Easy-peasy.
I am running PostmarketOS with great success. I have only been using it for a day, but it is very up-to-date. The only problem I have right now on the Librem 5 is the GPS is not working well - although it has often not worked well for me. (That is a long story that relates more to my use of the phone). Regardless, everything is working very well. I may return to PureOS when it gets updated to more modern software, but I must admit to being fed-up with the slow progress of that endeavor.
I am following up on this again. If people are not interested, no problem. I totally understand. Feel free to ignore this post.
If you are interested: I wanted to report that I can now visualize using the Librem 5 as my daily driver again. I am running PostmarketOS edge, with Phosh. Many of the annoying small issues have been fixed/improved. The battery is much improved. I have not run any tests, but it seems to last longer. Also, the phone never overheats - even if I abuse it by running a number of things and charging it at the same time. In the main, the applications are snappy and do what they are supposed to-do. Mobile Firefox runs well. Brave is also smoother and easier to work with. I have not tried Epiphany.
I really like the wallpapers and the new Phosh interfaces. Phosh 51.0 is a big improvement from what I was using on Byzantium. The layout and feel of Phosh makes it feel like a modern phone.
Bluetooth is improved but not perfect. Bluetooth continues to be slightly annoying but not unbearable.
I don’t know what keyboard I am using but I know it works. It is smoother with word-completion, etc. It also uses French quite well with no big issues (I know, probably not a big deal to most people).
I am having GPS issues, but that is nothing new for me. I am not sure if I have a faulty GPS receiver or not - seems like it.
There are other small details that make the phone seem “fresh”.
I should also be clear that I cancelled AWESim a few months ago. Therefore, I cannot comment on using the cellular service for calls and texts. I can, however, report that using Gnome Calls works quite well with JMP.chat as a VOIP or SIP service based on XMPP. Calls might break (that has happened to me in the past) but for now I am very pleased. I do have to use a headphone for calls though as the annoying echo issues associated with the odd microphone speaker issues are on-going.
Not everything is perfect in Linux Mobile with PostmarketOS but there seems to be a lot of light at the end of this tunnel. I am not fond of Alpine Linux and the apk package system, but it isn’t too difficult. I prefer Debian. There also does not seem to be a lot of support for questions. I must say that this forum is pretty excellent, so that is a win for Purism.
I will likely move back to PureOS and Debian if Purism can ever get to Trixie or whatever is comparable to the current PostmarketOS level. For now, I am very pleased. I probably should have tried this sooner but I can confidently say that the Librem 5 does get better with age and, more importantly, software development.
I am bumping this to report that GPS finally works better than it ever has with PmOS. I am very happy with it. I can explain more about how I got it working if anyone is interested.
Also, bluetooth works very well! Not perfect, but I am ok with it.
Still no report on calls or sms as I am not dailying it yet.
@dos
Either way Postmarket and Mobian it not dedicated for L5, so this OSes do not ship Zero Day fixes for L5.
I am on Gnu Crimson and Calls, SMS, and MMS worked extremely nice, the only issue is GTK it not optimized for mobile devices-L5 which create a CPU resource bottleneck can interfere with an active call quality and others systems task. Chatty was upgraded on Crimson which add fixes.
You probably feel that Postmarket works better right now because it integrates new software from Gnome which are not credits for postmarket.
