Screen not Cleared after Bad Passphrase on L5
After entering a bad decryption passphrase, I noticed the warning is not competely cleared off the screen when you enter a good one. It disappears too fast for me to remember it all, but the word “successfully” only partially overwrites the warning. Example:
successfullyed, b
Beginning of line says:
cryptcryptsetup
If this uses terminal I would think, a simple “clear” should do it.
I had reboot it several times to get the above in my head, it disappears after a second. No I won’t bother with a video. Besides the video would capture me entering the “correct” passphrase, unless I crop it.
That’s “normal” for now. I slightly remember that dos had sometime worked on cleaning the splash screen up. But it’s a bit ago and I could not find it again, so please don’t take that as 100% sure…
Also, the Librem 5 logo is blurred and the encryption phrase is more technical than enduser friendly for now.
Just thought I’d mention it. Otherwise it may be forgotten.
The best way to mention it would be to create an “Issue” - otherwise just posting something in this forum may lead to its being forgotten anyway.
I understand that you may not want the hassle of getting the account created so that you can report the Issue, assuming that you do not already have a suitable account.
