##### SET VALUES #####
# end_threshold has to be bigger than start_threshold
# add "-f force_start_value end_start_value" to command to force "charging to end"
wanted_start_threshold=20
wanted_end_threshold=93 #
time_interval=5 #
end_threshold=$wanted_end_threshold
force_start=$2
forec_end=$3
force=$1
if [[ $force_start != "" ]];then
wanted_start_threshold = $force_start
fi
if [[ $force_end != "" ]];then
wanted_start_threshold = $force_end
fi
echo "setup was:"
echo "start at: " $wanted_start_threshold
echo "end at: " $end_threshold
echo $force
# initialization
echo "INTIALIZING"
echo $end_threshold | sudo tee /sys/class/power_supply/BAT0/charge_control_end_threshold
while :
do
actual_capacity=$(cat /sys/class/power_supply/BAT0/capacity)
status=$(cat /sys/class/power_supply/BAT0/status)
echo "end_threshold is: "$end_threshold
echo "status is: "$status
echo "capacity is: "$actual_capacity
# if start_threshold is reached
if [[ $actual_capacity -lt $wanted_start_threshold ]] || [[ $1 == "-f" ]]; then
echo "STARTING charge to end"
echo $(($end_threshold - 1)) | sudo tee /sys/class/power_supply/BAT0/charge_control_start_threshold
fi
# if end_threshold is being reached
if [[ $(cat /sys/class/power_supply/BAT0/charge_control_start_threshold) -ge $(($end_threshold - 1)) ]]; then
echo "REACHING end_threshold"
fi
# If end_threshold is reached then reset start_threshold
if [[ $actual_capacity -ge $((end_threshold -1)) ]]; then
echo "ENDING: end_threshold reached, reseting threshold_files"
echo $wanted_start_threshold | sudo tee /sys/class/power_supply/BAT0/charge_control_start_threshold
fi
sleep $time_interval
done
script updated
