I would worry about the size…
When I imagine, I would have 3000, and each of them got like 17 different signatures for each occasion to be secure, in the final end, it’s like 3000174096kB… It’s 199MB’s of cryptographic signatures.
Or if you’re signed to lot of channels, or you use a software of lot people, 3000 connections is not a big number in today’s word.
Therefore, it means… There’s something like…
If I’ve got a problems with such small card. Imagine, each one every developer in commission must be signed to the update, otherwise you shouldn’t install it.
You use software from more people, because it’s precise software…
Funny this facebook and google market and things, when you can have just parsed everything you need.
But then there’s a bigger problem. I need to write only store every license with checksum of software I’m using. And for that 1TB write only SD card is not enough.
And I need to have it stored, so with this write only, we can have secure boot like no other, because nobody can however replace the checksum…
And yes, license is required if you’re parsing OP codes, because it’s necessary to do it with permission. Of course if it’s software from robots allowed part of internet, you don’t have to. Creating a robot, which consumes executable software on processor, and spews out new software isn’t illegal here, because here, my robots have own rights, given by unix kernel, and law is also applicable to your robots…
But then I need 10000 manhours of reading licenses or robot for doing that…
I would stick with having signatures of developers.
