[ 0.078691] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.078726] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.078733] pci 0000:00:1c.0: PCI bridge to [bus 02]
[ 0.078739] pci 0000:00:1c.0: bridge window [mem 0xd0500000-0xd05fffff]
[ 0.078748] pci 0000:00:1c.2: PCI bridge to [bus 03]
[ 0.078754] pci 0000:00:1c.2: bridge window [mem 0xd0400000-0xd04fffff]
[ 0.078763] pci 0000:00:1c.4: PCI bridge to [bus 04]
[ 0.078776] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.078777] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.078778] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.078780] pci_bus 0000:00: resource 7 [mem 0xbfa00000-0xfeafffff window]
[ 0.078781] pci_bus 0000:00: resource 8 [mem 0xfed40000-0xfed44fff window]
[ 0.078782] pci_bus 0000:02: resource 1 [mem 0xd0500000-0xd05fffff]
[ 0.078784] pci_bus 0000:03: resource 1 [mem 0xd0400000-0xd04fffff]
[ 0.078849] NET: Registered protocol family 2
[ 0.078978] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes)
[ 0.079007] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.079116] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.079238] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.079278] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.079303] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.079355] NET: Registered protocol family 1
[ 0.079370] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.079776] PCI: CLS 64 bytes, default 64
[ 0.079810] Unpacking initramfs...
[ 0.641304] Freeing initrd memory: 35788K
[ 0.664060] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.664075] software IO TLB [mem 0xb6c8f000-0xbac8f000] (64MB) mapped at [(____ptrval____)-(____ptrval____)]
[ 0.664658] Initialise system trusted keyrings
[ 0.664708] workingset: timestamp_bits=40 max_order=21 bucket_order=0
[ 0.665744] zbud: loaded
[ 0.665962] pstore: using deflate compression
[ 1.001174] Key type asymmetric registered
[ 1.001178] Asymmetric key parser 'x509' registered
[ 1.001212] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[ 1.001242] io scheduler noop registered
[ 1.001244] io scheduler deadline registered
[ 1.001280] io scheduler cfq registered (default)
[ 1.001283] io scheduler mq-deadline registered
[ 1.001712] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 1.001724] vesafb: mode is 1024x768x32, linelength=4096, pages=0
[ 1.001726] vesafb: scrolling: redraw
[ 1.001729] vesafb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 1.001741] vesafb: framebuffer at 0xc0000000, mapped to 0x(____ptrval____), using 3072k, total 3072k
[ 1.048707] Console: switching to colour frame buffer device 128x48
[ 1.096179] fb0: VESA VGA frame buffer device
[ 1.096578] intel_idle: MWAIT substates: 0x21120
[ 1.096578] intel_idle: v0.4.1 model 0x2A
[ 1.096710] intel_idle: lapic_timer_reliable_states 0xffffffff
[ 1.096934] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.097857] Linux agpgart interface v0.103
[ 1.098258] AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[ 1.098788] AMD IOMMUv2 functionality not available on this system
[ 1.099571] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 1.106207] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.106650] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.107240] mousedev: PS/2 mouse device common for all mice
[ 1.107763] rtc_cmos 00:01: RTC can wake from S4
[ 1.108347] rtc_cmos 00:01: registered as rtc0
[ 1.108750] rtc_cmos 00:01: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[ 1.109429] intel_pstate: Intel P-state driver initializing
[ 1.110208] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.113296] NET: Registered protocol family 10
[ 1.115484] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[ 1.122933] Segment Routing with IPv6
[ 1.123246] mip6: Mobile IPv6
[ 1.123634] NET: Registered protocol family 17
[ 1.124579] mpls_gso: MPLS GSO support
[ 1.126039] microcode: sig=0x206a7, pf=0x10, revision=0x23
[ 1.126685] microcode: Microcode Update Driver: v2.2.
[ 1.126704] sched_clock: Marking stable (1126674178, 0)->(1116484640, 10189538)
[ 1.172877] registered taskstats version 1
[ 1.189106] Loading compiled-in X.509 certificates
[ 1.247465] Loaded X.509 cert 'secure-boot-test-key-lfaraone: 97c1b25cddf9873ca78a58f3d73bf727d2cf78ff'
[ 1.284906] zswap: loaded using pool lzo/zbud
[ 1.303507] AppArmor: AppArmor sha1 policy hashing enabled
[ 1.320307] rtc_cmos 00:01: setting system clock to 2018-11-12 19:24:42 UTC (1542050682)
[ 1.338150] Freeing unused kernel image memory: 1548K
[ 1.372109] Write protecting the kernel read-only data: 16384k
[ 1.429373] Freeing unused kernel image memory: 2028K
[ 1.446164] Freeing unused kernel image memory: 836K
[ 1.468612] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.485046] x86/mm: Checking user space page tables
[ 1.507309] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.657154] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2
[ 1.676035] ACPI: Power Button [PWRB]
[ 1.694005] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input3
[ 1.696025] tsc: Refined TSC clocksource calibration: 2790.934 MHz
[ 1.712392] ACPI: Sleep Button [SLPB]
[ 1.730622] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x283acc80692, max_idle_ns: 440795346123 ns
[ 1.768039] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input4
[ 1.787280] clocksource: Switched to clocksource tsc
[ 1.787292] ACPI: Lid Switch [LID0]
[ 1.825059] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input5
[ 1.844242] ACPI: Power Button [PWRF]
[ 1.864473] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[ 1.884017] ACPI: bus type USB registered
[ 1.903191] usbcore: registered new interface driver usbfs
[ 1.904793] wmi_bus wmi_bus-PNP0C14:00: WQBC data block query control method not found
[ 1.922357] usbcore: registered new interface driver hub
[ 1.960231] usbcore: registered new device driver usb
[ 1.982138] SCSI subsystem initialized
[ 2.001325] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.021959] thermal LNXTHERM:00: registered as thermal_zone0
[ 2.041641] ACPI: Thermal Zone [TZ00] (65 C)
[ 2.061353] cryptd: max_cpu_qlen set to 1000
[ 2.061552] thermal LNXTHERM:01: registered as thermal_zone1
[ 2.099838] ACPI: Thermal Zone [TZ01] (65 C)
[ 2.119899] ehci-pci: EHCI PCI platform driver
[ 2.132046] libata version 3.00 loaded.
[ 2.138965] ehci-pci 0000:00:1a.0: EHCI Host Controller
[ 2.157813] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 2.176837] ehci-pci 0000:00:1a.0: debug port 2
[ 2.196427] AVX version of gcm_enc/dec engaged.
[ 2.199519] ehci-pci 0000:00:1a.0: cache line size of 64 is not supported
[ 2.215205] AES CTR mode by8 optimization enabled
[ 2.215215] ehci-pci 0000:00:1a.0: irq 16, io mem 0xd060a000
[ 2.253522] alg: No test for pcbc(aes) (pcbc-aes-aesni)
[ 2.272283] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[ 2.291078] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.18
[ 2.309362] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.327356] usb usb1: Product: EHCI Host Controller
[ 2.327432] ahci 0000:00:1f.2: version 3.0
[ 2.345774] usb usb1: Manufacturer: Linux 4.18.0-2-amd64 ehci_hcd
[ 2.345944] ahci 0000:00:1f.2: SSS flag set, parallel bus scan disabled
[ 2.364259] usb usb1: SerialNumber: 0000:00:1a.0
[ 2.392767] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x13 impl SATA mode
[ 2.400961] hub 1-0:1.0: USB hub found
[ 2.419379] ahci 0000:00:1f.2: flags: 64bit ncq sntf stag pm led clo pio slum part ems sxs apst
[ 2.449101] scsi host0: ahci
[ 2.456964] hub 1-0:1.0: 2 ports detected
[ 2.494586] scsi host1: ahci
[ 2.496009] xhci_hcd 0000:03:00.0: xHCI Host Controller
[ 2.513378] scsi host2: ahci
[ 2.531850] xhci_hcd 0000:03:00.0: new USB bus registered, assigned bus number 2
[ 2.568033] scsi host3: ahci
[ 2.569415] xhci_hcd 0000:03:00.0: hcc params 0x014042cb hci version 0x96 quirks 0x0000000000000004
[ 2.587856] scsi host4: ahci
[ 2.606734] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.18
[ 2.625264] scsi host5: ahci
[ 2.643792] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.643794] usb usb2: Product: xHCI Host Controller
[ 2.643795] usb usb2: Manufacturer: Linux 4.18.0-2-amd64 xhci-hcd
[ 2.662251] ata1: SATA max UDMA/133 abar m2048@0xd0608000 port 0xd0608100 irq 26
[ 2.680645] usb usb2: SerialNumber: 0000:03:00.0
[ 2.680649] checking generic (c0000000 300000) vs hw (c0000000 10000000)
[ 2.680799] hub 2-0:1.0: USB hub found
[ 2.680811] hub 2-0:1.0: 2 ports detected
[ 2.680952] xhci_hcd 0000:03:00.0: xHCI Host Controller
[ 2.680955] xhci_hcd 0000:03:00.0: new USB bus registered, assigned bus number 3
[ 2.680959] xhci_hcd 0000:03:00.0: Host supports USB 3.0 SuperSpeed
[ 2.680990] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
[ 2.681020] usb usb3: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.18
[ 2.681021] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.681022] usb usb3: Product: xHCI Host Controller
[ 2.681023] usb usb3: Manufacturer: Linux 4.18.0-2-amd64 xhci-hcd
[ 2.681024] usb usb3: SerialNumber: 0000:03:00.0
[ 2.681120] hub 3-0:1.0: USB hub found
[ 2.681130] hub 3-0:1.0: 2 ports detected
[ 2.698800] ata2: SATA max UDMA/133 abar m2048@0xd0608000 port 0xd0608180 irq 26
[ 2.698805] ehci-pci 0000:00:1d.0: EHCI Host Controller
[ 2.698812] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 4
[ 2.698825] ehci-pci 0000:00:1d.0: debug port 2
[ 2.702719] ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
[ 2.702733] ehci-pci 0000:00:1d.0: irq 23, io mem 0xd0609000
[ 2.717168] fb: switching to inteldrmfb from VESA VGA
[ 2.735457] ata3: DUMMY
[ 2.735467] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 2.735505] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.18
[ 2.735506] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.735508] usb usb4: Product: EHCI Host Controller
[ 2.735509] usb usb4: Manufacturer: Linux 4.18.0-2-amd64 ehci_hcd
[ 2.735510] usb usb4: SerialNumber: 0000:00:1d.0
[ 2.735610] hub 4-0:1.0: USB hub found
[ 2.735615] hub 4-0:1.0: 2 ports detected
[ 2.864006] usb 1-1: new high-speed USB device number 2 using ehci-pci
[ 2.875175] ata4: DUMMY
[ 3.048385] usb 1-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
[ 3.049488] ata5: SATA max UDMA/133 abar m2048@0xd0608000 port 0xd0608300 irq 26
[ 3.056001] usb 2-2: new low-speed USB device number 2 using xhci_hcd
[ 3.067176] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.084846] ata6: DUMMY
[ 3.088004] usb 4-1: new high-speed USB device number 2 using ehci-pci
[ 3.102537] hub 1-1:1.0: USB hub found
[ 3.288405] usb 4-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
[ 3.302657] hub 1-1:1.0: 6 ports detected
[ 3.319729] usb 4-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.320045] hub 4-1:1.0: USB hub found
[ 3.402184] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 3.404167] hub 4-1:1.0: 8 ports detected
[ 3.425402] ata1.00: ATA-8: WDC WD7500BPVT-75HXZT3, 03.01A03, max UDMA/133
[ 3.442054] usb 2-2: New USB device found, idVendor=093a, idProduct=2510, bcdDevice= 1.00
[ 3.453876] ata1.00: 1465149168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 3.470147] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.470157] usb 2-2: Product: USB OPTICAL MOUSE
[ 3.490469] ata1.00: configured for UDMA/133
[ 3.502491] usb 2-2: Manufacturer: PIXART
[ 3.519346] scsi 0:0:0:0: Direct-Access ATA WDC WD7500BPVT-7 1A03 PQ: 0 ANSI: 5
[ 3.620083] Console: switching to colour dummy device 80x25
[ 3.620479] [drm] Replacing VGA console driver
[ 3.622446] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.626279] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 3.626286] [drm] Driver supports precise vblank timestamp query.
[ 3.627249] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 3.635285] usbcore: registered new interface driver usbhid
[ 3.635293] usbhid: USB HID core driver
[ 3.636797] input: PIXART USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:1c.2/0000:03:00.0/usb2/2-2/2-2:1.0/0003:093A:2510.0001/input/input7
[ 3.636895] hid-generic 0003:093A:2510.0001: input,hidraw0: USB HID v1.11 Mouse [PIXART USB OPTICAL MOUSE] on usb-0000:03:00.0-2/input0
[ 3.648154] [drm] Initialized i915 1.6.0 20180514 for 0000:00:02.0 on minor 0
[ 3.649394] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 3.649950] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input8
[ 3.663781] fbcon: inteldrmfb (fb0) is primary device
[ 3.700090] usb 1-1.1: new high-speed USB device number 3 using ehci-pci
[ 3.728236] usb 4-1.5: new full-speed USB device number 3 using ehci-pci
[ 3.764591] psmouse serio1: synaptics: queried max coordinates: x [..5798], y [..4992]
[ 3.782671] random: fast init done
[ 3.835534] psmouse serio1: synaptics: Touchpad model: 1, fw: 7.5, id: 0x1e0b1, caps: 0xd00073/0x240000/0x8a0400/0x0, board id: 1648, fw id: 720989
[ 3.837269] usb 4-1.5: New USB device found, idVendor=0cf3, idProduct=3002, bcdDevice= 0.01
[ 3.837276] usb 4-1.5: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.886113] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio1/input/input6
[ 3.935335] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 3.938341] ata2.00: ATAPI: HL-DT-ST DVDRW/BDROM CT40N, A101, max UDMA/133
[ 3.943345] ata2.00: configured for UDMA/133
[ 3.948220] scsi 1:0:0:0: CD-ROM HL-DT-ST DVDRWBD CT40N A101 PQ: 0 ANSI: 5
[ 4.291613] ata5: SATA link down (SStatus 0 SControl 300)
[ 4.514005] Console: switching to colour frame buffer device 170x48
[ 4.538533] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[ 4.560288] sd 0:0:0:0: [sda] 1465149168 512-byte logical blocks: (750 GB/699 GiB)
[ 4.560339] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 4.560507] sd 0:0:0:0: [sda] Write Protect is off
[ 4.560550] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 4.560685] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 4.594179] sr 1:0:0:0: [sr0] scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[ 4.594290] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 4.595068] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 4.595375] sda: sda1 sda2 sda3 sda4
[ 4.596693] sd 0:0:0:0: [sda] Attached SCSI disk
[ 5.313657] random: lvm: uninitialized urandom read (4 bytes read)
[ 5.424720] random: lvm: uninitialized urandom read (4 bytes read)
[ 5.455747] device-mapper: uevent: version 1.0.3
[ 5.457089] device-mapper: ioctl: 4.39.0-ioctl (2018-04-03) initialised: dm-devel@redhat.com
[ 7.536781] NET: Registered protocol family 38
[ 9.004007] usb 1-1.1: device descriptor read/64, error -110
[ 9.753880] random: cryptsetup: uninitialized urandom read (2 bytes read)
[ 9.907019] PM: Image not found (code -22)
[ 10.061650] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null)
[ 11.878647] systemd[1]: systemd 239 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 11.904562] systemd[1]: Detected architecture x86-64.
[ 11.951750] systemd[1]: Set hostname to <democracy>.
[ 13.494318] systemd[1]: /etc/systemd/system/rc-local.service:11: Support for option SysVStartPriority= has been removed and it is ignored
[ 13.964197] random: systemd: uninitialized urandom read (16 bytes read)
[ 13.968733] systemd[1]: Created slice User and Session Slice.
[ 13.971634] random: systemd: uninitialized urandom read (16 bytes read)
[ 13.974513] systemd[1]: Listening on LVM2 poll daemon socket.
[ 13.981161] random: systemd: uninitialized urandom read (16 bytes read)
[ 13.981261] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 13.990344] systemd[1]: Listening on udev Control Socket.
[ 13.992504] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 13.994636] systemd[1]: Reached target User and Group Name Lookups.
[ 14.528209] EXT4-fs (dm-0): re-mounted. Opts: (null)
[ 14.635281] systemd-journald[355]: Received request to flush runtime journal from PID 1
[ 14.678920] lp: driver loaded but no devices found
[ 14.834412] ppdev: user-space parallel port driver
[ 15.412106] usb 1-1.1: device descriptor read/64, error -71
[ 15.600041] usb 1-1.1: new high-speed USB device number 4 using ehci-pci
[ 15.861987] loop: module loaded
[ 16.307696] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 17.788960] ACPI: Battery Slot [BAT0] (battery present)
[ 17.867089] audit: type=1400 audit(1542050699.043:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="klogd" pid=457 comm="apparmor_parser"
[ 17.876064] ACPI: AC Adapter [ADP0] (on-line)
[ 18.047722] input: PC Speaker as /devices/platform/pcspkr/input/input9
[ 18.090411] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[ 18.097851] iTCO_vendor_support: vendor-support=0
[ 18.148558] audit: type=1400 audit(1542050699.327:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="syslogd" pid=455 comm="apparmor_parser"
[ 18.150048] audit: type=1400 audit(1542050699.327:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="ping" pid=454 comm="apparmor_parser"
[ 18.174586] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 18.175730] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 18.210611] input: Dell WMI hotkeys as /devices/platform/PNP0C14:00/wmi_bus/wmi_bus-PNP0C14:00/9DBB5994-A997-11DA-B012-B622A1EF5492/input/input10
[ 18.230853] RAPL PMU: API unit is 2^-32 Joules, 3 fixed counters, 163840 ms ovfl timer
[ 18.231799] RAPL PMU: hw unit of domain pp0-core 2^-16 Joules
[ 18.232769] RAPL PMU: hw unit of domain package 2^-16 Joules
[ 18.233818] RAPL PMU: hw unit of domain pp1-gpu 2^-16 Joules
[ 18.278978] audit: type=1400 audit(1542050699.455:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=484 comm="apparmor_parser"
[ 18.281472] audit: type=1400 audit(1542050699.455:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=484 comm="apparmor_parser"
[ 18.282863] audit: type=1400 audit(1542050699.455:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=484 comm="apparmor_parser"
[ 18.323619] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[ 18.325536] iTCO_wdt: Found a Cougar Point TCO device (Version=2, TCOBASE=0x0460)
[ 18.326973] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 18.372636] audit: type=1400 audit(1542050699.551:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/dovecot/anvil" pid=493 comm="apparmor_parser"
[ 18.426558] audit: type=1400 audit(1542050699.603:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="syslog-ng" pid=456 comm="apparmor_parser"
[ 18.471535] audit: type=1400 audit(1542050699.647:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/dovecot/auth" pid=499 comm="apparmor_parser"
[ 18.535496] audit: type=1400 audit(1542050699.711:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/dovecot/config" pid=507 comm="apparmor_parser"
[ 19.664628] intel_rapl: Found RAPL domain package
[ 19.666382] intel_rapl: Found RAPL domain core
[ 19.666383] intel_rapl: Found RAPL domain uncore
[ 19.930611] snd_hda_intel 0000:00:1b.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 19.931755] Bluetooth: Core ver 2.22
[ 19.934015] NET: Registered protocol family 31
[ 19.935702] Bluetooth: HCI device and connection manager initialized
[ 19.938091] Bluetooth: HCI socket layer initialized
[ 19.940133] Bluetooth: L2CAP socket layer initialized
[ 19.941845] Bluetooth: SCO socket layer initialized
[ 20.071813] ath: phy0: ASPM enabled: 0x42
[ 20.073472] ath: EEPROM regdomain: 0x60
[ 20.073473] ath: EEPROM indicates we should expect a direct regpair map
[ 20.073474] ath: Country alpha2 being used: 00
[ 20.073475] ath: Regpair used: 0x60
[ 20.121242] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC269VB: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 20.122985] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 20.124725] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 20.126440] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 20.128146] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 20.136713] snd_hda_codec_realtek hdaudioC0D0: Mic=0x18
[ 20.138405] snd_hda_codec_realtek hdaudioC0D0: Internal Mic=0x12
[ 20.179819] usbcore: registered new interface driver btusb
[ 20.233142] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 20.233409] ieee80211 phy0: Atheros AR9285 Rev:2 mem=0xffffabcc015e0000, irq=16
[ 20.273554] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[ 20.275480] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
[ 20.277437] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input13
[ 20.279130] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input14
[ 20.320614] usb 4-1.5: firmware: failed to load ath3k-1.fw (-2)
[ 20.322192] firmware_class: See https://wiki.debian.org/Firmware for information about missing firmware
[ 20.323752] usb 4-1.5: Direct firmware load for ath3k-1.fw failed with error -2
[ 20.325351] Bluetooth: Firmware file "ath3k-1.fw" not found
[ 20.326831] ath3k: probe of 4-1.5:1.0 failed with error -2
[ 20.328938] usbcore: registered new interface driver ath3k
[ 20.780006] usb 1-1.1: device descriptor read/64, error -110
[ 20.982861] ath9k 0000:02:00.0 wlp2s0: renamed from wlan0
[ 22.704899] random: crng init done
[ 22.705940] random: 4 urandom warning(s) missed due to ratelimiting
[ 27.160054] usb 1-1.1: device descriptor read/64, error -71
[ 27.268151] usb 1-1-port1: attempt power cycle
[ 27.872082] usb 1-1.1: new high-speed USB device number 5 using ehci-pci
[ 29.490732] kauditd_printk_skb: 54 callbacks suppressed
[ 29.490733] audit: type=1400 audit(1542050710.666:66): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="/snap/core/5742/usr/lib/snapd/snap-confine" pid=981 comm="apparmor_parser"
[ 29.492694] audit: type=1400 audit(1542050710.666:67): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="/snap/core/5742/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=981 comm="apparmor_parser"
[ 29.494489] audit: type=1400 audit(1542050710.670:68): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="snap.core.hook.configure" pid=986 comm="apparmor_parser"
[ 30.972232] IPv6: ADDRCONF(NETDEV_UP): wlp2s0: link is not ready
[ 30.989001] IPv6: ADDRCONF(NETDEV_UP): wlp2s0: link is not ready
[ 31.011666] IPv6: ADDRCONF(NETDEV_UP): wlp2s0: link is not ready
[ 31.354419] IPv6: ADDRCONF(NETDEV_UP): wlp2s0: link is not ready
[ 32.140182] usb 1-1.1: device not accepting address 5, error -71
[ 32.428095] usb 1-1.1: new high-speed USB device number 6 using ehci-pci
[ 32.456951] IPv6: ADDRCONF(NETDEV_UP): wlp2s0: link is not ready
[ 33.566711] wlp2s0: authenticate with 00:1a:3f:db:e6:76
[ 33.580732] wlp2s0: send auth to 00:1a:3f:db:e6:76 (try 1/3)
[ 33.582783] wlp2s0: authenticated
[ 33.584146] wlp2s0: associate with 00:1a:3f:db:e6:76 (try 1/3)
[ 33.588057] wlp2s0: RX AssocResp from 00:1a:3f:db:e6:76 (capab=0x431 status=0 aid=2)
[ 33.588194] wlp2s0: associated
[ 33.879958] IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0: link becomes ready
[ 43.180498] usb 1-1.1: device not accepting address 6, error -110
[ 43.180724] usb 1-1-port1: unable to enumerate USB device
[ 43.260511] usb 1-1.4: new high-speed USB device number 7 using ehci-pci
[ 43.483395] usb 1-1.4: New USB device found, idVendor=1bcf, idProduct=2880, bcdDevice=15.13
[ 43.483409] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 43.483416] usb 1-1.4: Product: Laptop_Integrated_Webcam_HD
[ 43.483422] usb 1-1.4: Manufacturer: CN0T3NPC724871AHKMM6A00
[ 43.798590] media: Linux media interface: v0.10
[ 43.861174] videodev: Linux video capture interface: v2.00
[ 44.121070] uvcvideo: Found UVC 1.00 device Laptop_Integrated_Webcam_HD (1bcf:2880)
[ 44.154489] uvcvideo 1-1.4:1.0: Entity type for entity Extension 4 was not initialized!
[ 44.154503] uvcvideo 1-1.4:1.0: Entity type for entity Extension 3 was not initialized!
[ 44.154509] uvcvideo 1-1.4:1.0: Entity type for entity Processing 2 was not initialized!
[ 44.154515] uvcvideo 1-1.4:1.0: Entity type for entity Camera 1 was not initialized!
[ 44.154843] input: Laptop_Integrated_Webcam_HD: In as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4:1.0/input/input15
[ 44.155164] usbcore: registered new interface driver uvcvideo
[ 44.155173] USB Video Class driver (1.1.1)
[ 44.660689] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 44.660699] Bluetooth: BNEP filters: protocol multicast
[ 44.660711] Bluetooth: BNEP socket layer initialized
[ 44.677323] input: BRLTTY 5.6 Linux Screen Driver Keyboard as /devices/virtual/input/input16
[ 49.824666] usb 1-1.1: new high-speed USB device number 8 using ehci-pci
[ 50.428728] usb 1-1.1: device descriptor read/64, error -71
[ 60.387383] fuse init (API version 7.27)
[ 60.588572] usb 1-1.1: device descriptor read/64, error -71
[ 60.776689] usb 1-1.1: new high-speed USB device number 9 using ehci-pci
[ 65.297912] rfkill: input handler disabled
[ 66.104481] usb 1-1.1: device descriptor read/64, error -110
[ 70.638839] usb 1-1.1: device descriptor read/64, error -71
[ 70.747120] usb 1-1-port1: attempt power cycle
[ 71.351239] usb 1-1.1: new high-speed USB device number 10 using ehci-pci
[ 74.976739] usb 1-1.1: device not accepting address 10, error -71
[ 75.264871] usb 1-1.1: new high-speed USB device number 11 using ehci-pci
[ 83.507644] usb 1-1.1: device not accepting address 11, error -71
[ 83.507776] usb 1-1-port1: unable to enumerate USB device
[ 83.731723] usb 1-1.1: new high-speed USB device number 12 using ehci-pci
[ 88.897052] usb 1-1.1: device descriptor read/64, error -110
[ 94.002169] usb 1-1.1: device descriptor read/64, error -71
[ 94.190207] usb 1-1.1: new high-speed USB device number 13 using ehci-pci
This is a dmseg after a reboot and without a SD Card inserted. Even after inserting, it keep giving the same errors, like
[ 351.299910] usb 1-1-port1: attempt power cycle
[ 351.903853] usb 1-1.1: new high-speed USB device number 42 using ehci-pci
[ 357.200004] usb 1-1.1: device not accepting address 42, error -71
[ 357.488002] usb 1-1.1: new high-speed USB device number 43 using ehci-pci
[ 367.784562] usb 1-1.1: device not accepting address 43, error -71
[ 367.784698] usb 1-1-port1: unable to enumerate USB device
[ 368.008663] usb 1-1.1: new high-speed USB device number 44 using ehci-pci
[ 373.312980] usb 1-1.1: device descriptor read/64, error -110
