Hi,
After the last update, the Show Battery Percentage icon disappeared as did the entry on the power settings. Any idea how to get it back?
Thanks!
Hi,
Thanks!
Deleted because may diffent bug.
Turn off the Librem 14, disconnect the AC power adapter, then turn on the Librem 14 using only battery power to force PureOS to detect it.
I think that it might be related to this: Librem 14 Battery Won't Charge
