Hi,
I have recently replaced Qubes 4.0.4 with 4.1.1 by performing a clean installation on my Librem 14, updated Pureboot to Release 24, EC to 1.11
There are two things that no longer work:
Shutdown - although the Qubes shuts down, the hardware remains running and I had to press power button to make sure the hardware is off.
Wake up from Suspend - the OS suspends, but again, the power on hardware remains on. Pressing any keys, won’t wake up the laptop. The only way out it to press and hold power button to shut the laptop completely and start again.
Observations:
DKSM
Instructions to install librem-ec-acpi-dkms in Qubes no longer work at the below step:
[user@dom0 5.15.81-1.fc32.qubes.x86_64]$ sudo make prepare
SYNC include/config/auto.conf.cmd
make[1]: *** No rule to make target ‘arch/x86/entry/syscalls/syscall_32.tbl’, needed by ‘arch/x86/include/generated/uapi/asm/unistd_32.h’. Stop.
make: *** [arch/x86/Makefile:217: archheaders] Error 2
GRUB
I have switched the graphical interface off in GRUB and updated it. When rebuilding initrd I get this error:
[user@dom0 boot$ sudo dracut -f
cat: /sys/power/resume: no such file or directory
Who has wake from suspend working in the same environment? I need your help to make it work please
Notify @Kyle_Rankin and @jonathon.hall
Update: 01/18/2023 - this issue is probably not related to the OS nor the EC. I will update the post as soon as the cause is identified.
