Hello Forum,
The Librem 5 arrived a couple of days ago without any problems.
I’ve been using it for a couple of days now, getting to know how it works and overall I’m satisfied, I know that designing a phone with such unique features as the Librem 5 is not easy.
There are some bugs that I think will be solved with time but the most important one is with the sim that ended up broken.
I had it one day connected by wifi and it is quite stable, loading updates and applications from the Pure OS Store, but the phone gets a bit hot and the consumption is a bit high (I guess the INX8 chip consumes).
Now I am going to talk about the call and data problems. With the sim the data was not stable and after a while I stopped having internet and to get it back I either restarted or had to activate or deactivate the phone settings.
It doesn’t make or receive calls, sms if they seem to work I sent a couple and another phone received them.
I am from Spain and have Vodafone.
I put the sim in my other Oneplus phone and this one does not detect it, it seems that the sim chip has been damaged.
I will keep an eye on the forum in case there are any similar incidents.
