Often when I’m running Boxes VM when I switch between the host OS and the VM, then back, the mouse disappears.
Shutting down Boxes and then re-starting fixes it… until I have to swing between host and the VM.
Anyone have the problem and know a fix?
Try this command to reset the mouse:
sudo rmmod psmouse; sudo modprobe psmouse
I have to do this so often on my laptop, that I have set up a custom key combination (CTL+ALT+m) to execute it.
