Sorry if some questions are stupid but im not a pro i keep discover things and i have some doubt
does it use a libre kernel freee from blobs? Like trisquel does
<li>i tryed the first alpha on virtualbox and i wasnt able on "store" to make any search is normal because is alpha or what?</li>
<li>app and kernel repository are from debian (like mint are from ubuntu) or is your own? Or from debian but verified by you?</li>
<li>any update manager will be on the os for app, kernel and security update as mint do? Or will be everything (or part of them) on terminal?</li>
<li>any eta for the final release?</li>
<li>the support will have some kind of LTS? Or how do u plan the end of life for every version?</li>
<li>do we have a chance to upgrade from previews version easily like just a command or the update manager? For noobs like me :)</li>
Thanks for the answers, cant wait for use it
any chance to have a custom script inside the update manager for upgrade it automatically with just a click?
about the 2nd point
i’ve installed the lastes apha on virtualbox and updated trough the software manager, now i have prometheus immage on desktop, but on the store i cant search anything on repository, it seems he research just the local programs
deb http://repo.puri.sm/pureos/ green main
deb-src http://repo.puri.sm/pureos/ green main
should i add something else?
i’ve noticed on software center everything i’m searching is not found if not installed, but for example if i try to install something (like i’ve done with cinnamon) on terminal everythings works fine
