nldude
July 2, 2023, 11:53am
1
Received my L5 in 2022, slowly starting to use it.
Since the beginning getting the above message.
It always comes when checking updates:
Settings -> About -> Software Updates
The screen comes:
Loading updates
followed by the above message in a black box with a close icon (X)
Sorry, something went wrong:
mkdirat: Permission denied
followed by the screen Up to Date (in case everything is up to date).
Sometimes it also pops up when doing other things, do not remember.
The update process seems to work without problems.
Software on the phone is (looks) up to date.
Any suggestions?
The GUI PureOS store does not work too well. You should go to terminal and type:
sudo apt update && sudo apt full-upgrade
and
sudo flatpak update
To update all your software.
Thanks but this did not help.
sudo flatpak update
gave:
Looking for updates …
Nothing to do.
Same after restart.
Get another message now after ‘Loading Updates’, in a black box with a close icon (X):
Unable to get list of updates:
E: Failed to fetch https://repo.pureos.netpureos/dictsbyzantiumInRelease
When I close this, the mentioned 'Sorry, something went wrong … ’ message appears.
Any suggestions?
flatpak update does not require sudo
@nldude
Could you give us the output of cat /etc/apt/sources.list ?
cat /etc/apt/sources.llst
deb https://repo.pureos.net/pureos byzantium main
deb https://repo.pureos.net/pureos byzantium-updates main
deb https://repo.pureos.net/pureos byzantium-security main
Okay that looks normal to me. Will give more ideas once I have them.
