I’m wondering whether the PureOS category should be split into
PureOS on Purism hardware (Librem)
and
PureOS on random other hardware
(category names not as suggested, only for explanation)
There seems to be a steady stream of people attempting to install PureOS on random hardware, with varying degrees of success, and the usual problems with BIOS v. UEFI, hardware components that only work with blackbox software i.e. expectations should be “open”. It might work. It might not work. It might not work at all. It might basically work but some components don’t work - and enough might work to get those components working. Or maybe not.
On the other hand, it is expected that PureOS works on Purism hardware. So users ought only to be having problems with how to use PureOS etc. Where’s my favorite package, XYZ? Need version a.b.c of package XYZ?
