I copied it to the issue tracker https://gitlab.gnome.org/World/Phosh/squeekboard/-/issues/338
And itās now landed in PureOS.
And polytonic Greek has landed on my L5. This is great @dcz May I ask something⦠squeekboard uses some builtin font to draw the labels on the keyboard. The characters for the polytonic accents are too tiny and difficult to see. Would it be possible some how to scale up only these characters for the keyboard labels?
I am not talking about the keys that show letters with accents. I talk about the keys that show ONLY accents.
Could you come up with a design of how you want them to look? I recommend the issue tracker so that the shortcoming doesnāt get lost.
Just added an issue on the link you give above with screenshot. Maybe I have exaggerated with my gimp scale-up of the accents. I guess a 100% increase (is double the size) will be enough. And let me stress that this is not only for Greek. If another keyboard has keys with diacritics alone, those will also benefit from a scale up. It is the way fonts are designed that diacritics glyphs are the size that are put above letters so that font editors can compose the accented letters on the fly. But when you choose the proper key on a keyboard like squeekboard it helps vision to use a larger size.
Currently testing with 1.18.0 and while its not released yet in PureOS 10 i dont think, i just wanted to note that for me the keyboard panel opens with a delay of 3-5 seconds. Collapsing the keyboard panel takes maybe 0.5 second but that could be intentional for an animation.
The delay happens accross all apps and UIs.
- collapse
- expand
Thanks for the link and patch, also before i installed the merge i removed non pureos packages or obsolete packages:
aptitude search ā~oā
sudo aptitude purge ā~oā
For some reason that elliminated the delay in unfold after removing various 5.17 kernel patches and other things. Turns out pureos packages with squeekboard 1.18.0 already so my previous comment was incorrect.
"aptitude versions squeekboard
Package squeekboard:
p A 1.18.0-1pureos1 byza 500
i A 1.18.0-1+librem5ci413685 "
Now testing the merge squeekboard_1.18.0-1+librem5ci413685.70bf101_arm64
So far i am noticing:
- quick fold unfold of panel.
- no noticeable typing interaction delay, seems a little more responsive but not sure.
- holding any letter does not repeat letter or space when selecting space bar, for gnome desktop it would be nice if squeekboard would honor gsettings for a. time until repeating, b. speed of repeating.
Please give it some time for the delay to grow enough to be noticeable, and then report in the comments on the patch.
Not a bug. Buttons are not keys, they donāt send letters but sequences of any number of letters. Repeating sequences would be unexpected (www.www.www.www.). However, you can file an issue in the tracker to make an argument that it is desired and can work in some form.
Does anyone know if the squeekboard is still under developement? It hasnāt been updated for a year I think, I still prefer the layout on this keyboard over the Stevia, but Stevia keyboard is catching up a ton and gaining many features now.
I think it currently has no main developer, but there are still few contributions. But indeed not a good sign. I know Stevia is a good keyboard, but it will never match my needs. Currently on Mobian, Squeekboard is broken for some reason and since I can only use Stevia, I stopped nearly any testing on this device, just because it makes no fun to use to me. But I also think/hope PureOS devs will catch it up once they work on Dawn.
One drawback of stevia is that I donāt see any button to hide the keyboard, like squeekboard has.
Button to hide Squeekboard? Do you speak about the button on the bottom right? That is the Phosh-button for hiding any OSK. And newer versions of Phosh replaced it with the bar in the mid. Just hold it some time and OSK appears/disappears. You also can swipe Stevia to the bottom to hide it (which is not possible on Squeekboard, because it types on touch, not on release).
yes, the Phosh button to hide the OSK is what I was referring to. I finally figured out how to hide the keyboard by doing the long press on the black bar of space at the bottom of the screen, thank you. Also figured out how to use the downward swipe to hide stevia, thank you for the tip.
I felt like the design layout on stevia in the terminal is just too bad. Very hard to type. It does have nice features, but I think typing experience is the most important thing, that is why I went back to the squeekoard, but donāt see it has updates since 2024. It might reach its life time though.
