Startup Applications Librem 5
Question: Is it possible to set startup applications on the Librem 5?
I did not see any startup application setting and wanted to ask if there was an alternative method.
Install gnome-tweaks and use it if you want GUI interface. Gnome-tweaks does not scale to screen properly so you need to use phosh-mobile-settings and scale it or set whole display scale to something like 1.
Or you can put .desktop file to ~/.config/autostart/ folder and it will start on boot. If that folder does not exists you can just create it.
