Status of Calls and SMS on Librem 5
As I eagerly await my Librem 5, I am evaluating whether I will need an additional device (e.g. iPhone). I will be starting a new job in the fall, and I will need a phone that will reliably place and receive calls and SMS messages. What is the current status? Does the phone reliably receive calls and texts? Does it sometimes silently miss notifications, etc?
If the phone will adequately perform for calls and texts, then I will likely upgrade my order to the Librem 5 USA version to avoid getting a second phone.
P.S. I already anticipate needing multiple batteries to get through the day, but that’s another issue regarding whether the Librem 5 will perform adequately.
I think currently it works well enough for calls and regular SMS messages but you get trouble when someone tries to send you an MMS, as far as I know that is still silently discarded. I think that is about to get fixed, there has been significant progress on it, but it’s not done yet. See:
Not only is your inbound MMS message discarded but you also won’t receive any SMS for approximately 3 days.
It used to be like that, but I think that part has been fixed, it was the “handle transfer-route MT messages” fix in ModemManager (Making sure you're not a bot!) that has made its way into PureOS also about a month ago (see Document changes and release 1.14.12-0.1pureos2 into byzantium (d702914f) · Commits · Librem5 / debs / ModemManager · GitLab).
Thanks for the links. I really should upgrade from amber…
The fix for that is already in amber-phone as well.
