I was reading about the status of Heads and other Pureboot issues (coreboot, Librem key) and checked this link:
https://docs.puri.sm/PureBoot/Heads/User_Manual.html#current-status
which says that Heads is still in beta.
Is this information current? If not, is there any new documentation on how to install Heads with a Librem key on a Librem 13v3 with TPM?
Is there a simple command to verify presence of TPM?
Doesnât seem current for 13v3 with TPM.
I followed it on a new 15v3 with TPM the past 48 hours or so, with Librem Key.
Was able to install a pre-built Heads image, but too many errors to list and dialogs that donât make any sense regarding what to do.
Could boot POS with it, but latest Qubes couldnât even boot.
Now trying to build Heads from source in that doc.
Got as far as the âAdd binary blobsâ section.
There, the ./get_blobs.sh
script fails out with âDownloaded Intel Flash Descriptor has the wrong SHA256 hashâ
Seems to be because itâs not really downloaded, maybe because the source location gives a 404 error, if I try to go there manually via browser.
Iâm not able to reproduce this issue here - the get_blobs scripts work correctly for both Skylake and Kabylake devices. Please post the URL youâre manually using to test so I can check against the script / sources
Just to add some encouragement. I finally got up the courage to update my Librem 15v3 w/TPM to Coreboot/Heads (PureBoot) from the Coreboot/SeaBIOS it came with from the factory. I say âcourageâ because it is my primary machine and I feared a bricked laptop.
Following the instructions in the docs, it worked without any major hiccups. I do not use PureOS but rather run KDE Neon and did not have any problems. Upgrading and flashing the firmware isnât a novice-friendly procedure, but they tell you that right up front. Just follow the directions carefully and you should be fine. I just used the provided scripts and didnât compile anything from scratch.
One of the big factors in my decision to purchase the Librem laptop was the Librem Key and the ability to verify BIOS and /boot partition tampering. I finally got that to work and it is impressive.
thanks for the kind words. weâve done a lot of work to improve the usability of PureBoot over the last several months, but realize it still has a ways to go before it reaches âproduction levelâ quality/ease of use, etc.
