Strange freezing behavior
Status icons relating to kill-switches froze, terminal reboot command lagged, then reboot froze before shutdown with only one line of "^@"s across the top of the screen, after which I just removed the battery. Any known bugs that could have caused this?
Sadly i not a Guru yet to know whats going on in your device, however we are lucky to have one @guru here so may helping you. However i did a massive troubleshooting and researching yesterday on my L5 and i confident to tell you that the Librem 5 work really fancy even under Gnu Byzantium.
Also Gnu Librem 5 it is not for everyone, otherwise will got massive issues.
Yes
Pulseaudio not starting on reboot
Yay Guru responded…
What does this expresion mean in Spanish
You do not speak Spanish? as far i know you do
I do but I don‘t know “yay …”
It’s an interjection in English, meaning hooray!, hurrah!, great!, awesome!, nice!, sweet!, etc.: yay - Wiktionary, the free dictionary
I.e. it’s English and not following el DRAE ( Diccionario de la lengua española de la Real Academia Española) :slight_smile:
If people are going to mix languages in one post, that’s what <span lang=“xx”> can help with. :wink:
