i use a chromebook and i am trying to get that on my device it is but if i try to run or do anything with it i get this error i fr have no idea what to do:
Reading package lists… Done
Building dependency tree… Done
You might want to run ‘apt --fix-broken install’ to correct these.
libsecret-1-dev : Depends: libsecret-1-0 (= 0.20.4-2) but it is not going to be installed
Depends: gir1.2-secret-1 (= 0.20.4-2) but it is not going to be installed
Depends: libglib2.0-dev (>= 2.44.0) but it is not going to be installed
minecraft-launcher : Depends: default-jre but it is not going to be installed
Depends: libnspr4 (>= 2:4.9-2~) but it is not going to be installed
Depends: libnss3 (>= 2:3.22) but it is not going to be installed
E: Unmet dependencies. Try ‘apt --fix-broken install’ with no packages (or specify a solution).
