As the smallest idle time for automatic suspend is 15 minutes, is there a way to kick suspend from shell command?
try systemctl suspend. Works on Librem 5
You might have to do systemctl suspend -i if something is inhibiting suspend. Be careful using the -i option though.
There’s also a suspend entry in the power menu: pull down top-bar, power-button on the right.
And since you use shell anyway: you can reduce the suspend time via org.gnome.settings-daemon.plugins.power sleep-inactive-battery-timeout gsetting.
Thanks. This works fine:
$ gsettings get org.gnome.settings-daemon.plugins.power sleep-inactive-battery-timeout
900
$ gsettings set org.gnome.settings-daemon.plugins.power sleep-inactive-battery-timeout 120
120
