Hi everyone
I want to run TAILS from USB on my Librem 14. Can anyone tell me what key I tap to get into the boot options? I’ve looked but can’t find a definitive answer.
Thanks for any help here.
Hi everyone
If you are using Coreboot + SeaBIOS, use Esc. You can use the arrow keys to navigate PureBoot menus, then select “USB Boot”.
Thanks for that. I’m using pureboot. I don’t know how to get to the menu, but I’ll have a hunt,
When PureBoot is booting, you’ll see Automatic boot in 5 seconds unless interrupted by keypress....
Press Spacebar or any letter/number/punctuation key then to enter the menu.
The above quote only occurs if a compatible Nitrokey/Librem Key is successfully configured with PureBoot and connected to the Librem 14. Otherwise, if you see a different message prompt or do not have a Nitrokey/Librem Key, use the arrow keys to select “Exit to boot menu”, “Skip”, or similar options instead.
