Terminal to clipboard
If I do a long press in the browser on the text of your answer, I cant select anything. A menu pops up which me also does not select any item of its list. Just give it a shot on my text here in the browser.
It’s tricky, and there’s a slight delay, too.
Maybe it’s more of a drag across the words than a long-press.
And it works more smoothly in Terminal than in the text editor.
Edit: Yes, it’s definitely a long drag, rather than a simple long press. Apologies.
Long press gets you this limited dialog (Select All, and Paste):
In Web I can only select a single word by double-tapping, or the entire text by quadruple-tapping.
In Firefox, double-tapping a word adds the selection tools to each end of the word, which you can drag to the beginning and end of the text you want to copy (using the Menu options in Squeekboard, or the edit tools in the Firefox menu.).
IIUC this only works for content that your bash command can access, not for stuff that’s already shown in the terminal, right?
Trying to select in gedit today, I see lots of things happening at the same time when dragging across text:
  • portions of the text are highlighted (blue background)
  • little begin and end markers appear
  • below the text a small magnifying class appears
If I succeed to select the text I wanted, tapping on the end marker brings the ccp menu, so that part actually looks good.
Two concerns, still:
First, it seems to require a lot of practice to get the desired results, e.g., most of the time I could select only entire words, but sometimes I succeeded to let the selection stop in the middle of a word. I couldn’t yet figure out which gesture drives which kind of selection. The selection seems to have its own will, also jumping in unexpected ways. Also the magnifying glass with its animation is quite distracting.
Second, as I don’t see this in other applications, I wonder if we’re at the mercy of developers of each and every application to implement select functionality? Isn’t there a fundamental approach built into wayland / the basic toolkits?
Yeah, it’s definitely quirky. Place your finger or stylus at the desired starting point, then drag to wherever desired. If it selects an entire word or phrase and you want to shorten the selected area, drag one of the end “markers” to the appropriate place. This is much easier with a stylus pen than with a finger.
Tap one of the markers to get cut/copy/paste.
Then tap the screen to de-select the selected text. Long-press elsewhere in the screen (or inside another app) to get the marker again, and touch it to get the Select All or Paste icon.
Hopefully you’ve also discovered the “Terminal” keyboard option in Squeekboard, which includes a “Menu” button with all the select/copy/paste/delete functions. That should help when using all the other apps where copy/paste would be appropriate.
I think so.
:waving_hand::upside_down_face: Hi All, because last post is almost 4 years ago, hoping in the meanwhile situation is improved, please is there a way to select and copy part of terminal on Librem 5?
Thank you so much :folded_hands:
Contact Purism.
Press Shift (only available on squeekboard versions higher than that on Byzantium), and then try and select what you want. Then of course, use shift+ctrl+c to copy or the menu key in the action layout of squeekboard
Select how?
With your finger :neutral_face:
That’s what I tried, but didn’t work for me.
Thank you for your suggestion! I tried it but it doesn’t work for me, unfortunately! I’ve Crimson and squeekboard (I checked it using ps aux | grep -i squeekboard)
It is not a perfect solution but I found the Mate-Terminal to work better in many respects than the default Terminal (not sure what it is called, probably Gnome something or other). Give it a try: sudo apt install mate-terminal
Actually, it isn’t. There is a package (and binary) called gnome-terminal but it is not the default terminal on the Librem 5. That honour belongs to the package (and binary) called kgx (which is the station code for Kings Cross railway station in London - and I have no idea why the package was thus named).
You need at least Squeekboard version 1.43 to get access to Shift modifier. That comes with Dawn. Optionally you can backport it. But you also need a custom Squeekboard layout as my “Squick” to get access to Shift (or you can modify it by your own, which requires some time to do, but is not really hard to learn). As workaround just use the menu button on Squeekboards terminal. Not sure how it is going with Stevia (I don’t know from what version on it is a good option).
Default terminal layout has shift after ver. 1.43
Right, forgot about this, since I do not like a lot and therefor use the defaults (usable, but less efficient to me).
